Question about Dacor ECS127 Epicure Stainless Steel Electric Single Oven
Oven enamel chipping
Has anyone had problems with the enamel deteriorating and falling off on the inside of the oven? If so, how did you go about getting it repaired or replaced? I have a Dacor RSD30 Dual Fuel stove and the enamel is falling off the inner facing of the oven. It is 4 years old and I rarely use the oven. Any assistance would be appreciated. Thanks
  • 175 Answers
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Posted on Jan 13, 2007
How do I know if the enamel is coming off the bottom of my new oven only a day old
It would look like a chip came off the surface. The only way that can happen is if something hard hit the surface to make it chip off. It might be that something overflowed onto the surface and baked on it.
Nov 08, 2015 | Ovens
Oven enamel
your wiring is switched up. its a 220v check wiring diagram on the oven. make sure the neutral isn't switched around
May 28, 2017 | Ovens
How to fix enamel that is half burnt off
Hello dfleck - Unfortunately once the enamel is burnt or damaged, it cannot be repair and will need replacing. At this point, I would personally recommend consulting with a service technician to proceed further.
Apr 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Is the interior of the Neff B1691 oven made from vitreous enamel? The manual only describes it as 'enamel.' I'd like to use Oven Pride cleaner on it but it says to only leave the product on for two hours...
I have searched diligently and cannot find what the interior of the oven is made of. I suggest you open the owner's manual and find contact information for the manufacture. Call or email them for an answer.
Feb 09, 2011 | Neff B1691 Single circotherm super...
My oven has the blue enamel inside and I want to clean it. I read that the self cleaning mode can chip the blue enamel. Also I know that I should not use oven cleaner. What is the best method for...
Sorry to read about your problem, I hope this helps you out.
use regular oven cleaner, if you wish
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | KitchenAid KEBC208 Electric Double Oven
The enamel on the bottom of my oven has started to flake can i buy paint to repair it before it goes rusty
You can buy enamel paint , depends where the rust is, you can buy heat proof paint if it is inside the oven.
If it is outside then treat it with a rust inhibitng paint first.
Nov 09, 2010 | Ovens
Enamelware repair
I have used appliance touch up paint to repair scratches and chips on ovens on enemel with out any problems.
I do not think you will have a problem
I do believe that there is a specific touch up for white enamel, but I don't know about other colours
Please leave feedback.
Thanks.
Nov 13, 2009 | Ovens
I just noticed that the oven enamel is chipped in a few places where the racks sit. Do I need to replace the oven?
At this moment in time, there is no need to replace oven, it is quite o/k to carry on using it.
Please rate my solution.
Thanks.
Sep 19, 2009 | Ovens
I need to repair the enamel in the base of my oven. It has been removed in somne areas.
they make special appliance enamel touch up paint, which is good for a knick and a chip here and there. If its a bigger job than that, you may want to use a higher heat enamel. Ive used high heat engine enamel purchased at an auto parts store, which they formulate to work with the heat of car engines. It comes in a spray can, so it depends on the scope of the project/repair.
Aug 31, 2009 | Philips Ovens
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
1,084 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Jose Pino
Are you a Dacor Oven Expert? Answer questions, earn points and help others
