Question about Proview PL926WBi 19" LCD Monitor
Screen goes dark after a few seconds
Other posts indicate this is a common prob with this unit. I have replaced power board cap's c211 thru c217 and c12&13 .The only electrolitic's I haven't replaced are c201 (100uf/100v) and c22 which i have yet to determin the value of.
The problem remains I can now get it to stay on for 5 or 6 min. every now and then and the display is perfect but it goes dark then will only turn on for 4or 5 sec by looking close I can see that the display is still on but screen is dark.
Does anyone know where I can get a schematic this unit as it would aid trouble shooting greatly .
ALSO if you have any sugestions on how to correct this problem i would very much like to hear them thanks-gls1934
  • 1 more comment
  • Tribb Dec 23, 2008
    I have the same problem has one found out anything yet??
  • Vlace2005 Mar 27, 2009
    My monitor stays on for a good while at times and at other times it only stays on for a few secs.I can tell it is still on but it is black.I can turn it off and right back on and you can see it for a couple secs.then it goes black again.
  • jessejohn1 Apr 04, 2009
    I think that is the problem. I have a PL926Wbi, 19", 900W and it went partially dark, a bit pink warming up, started flickering, then 2 seconds and it goes black. Seems to be a bulb short out problem to me, proview support was not help, just wanted me to ship in and pay to fix it, wouldn't give me any ideas what it could be.
  • 3 Answers
I think you need new backlights, if it was the inverter or power supply (the same in this case), it would not come on for that long, even 4 or 5 seconds. This unit has four 2mm x 405mm ccfl bulbs (cold cathode fluorescent light) two on top and two on bottom which can act much like household fluorescent tubes, coming on only briefly or one bad one causing the others not to strike or to turn off with it. I haven't been able to find exact replacements yet but I have an email in to Proview parts. When I find a part number and price I will post it here. Also if there was a problem with your power supply board, especially capacators, you would most likely be able to see that.screen goes dark after a few seconds - 5b4a2c3.jpg
Posted on Feb 21, 2009
This is a problem with the backlights i just replaced them with some backlights from a lcd tv that had broke. i had to modify the case a little but once its together you cant tell the difference. has been working for an hour so far.
Posted on May 10, 2009
    Problem Solver:
  • 6 Answers
Sometime replacing capacitors MIGHT resolve these this problem.There an inverter I.C. chip "BIT3193G" which sometime goes bad. Also this unit is also known to have bad lamps. The lamps size is 2.6mm(D) x 414mm(L). If replacing capacitor didn't resolve the problem then you will need know electronics to fix the problem. I do repair on this board and offer my service on eBay.
Posted on Mar 21, 2009
  • 558 Answers
Capacitors are one part of the protection circuit there are transistors in the circuit that will may also need to be replaced they handle the switching for the lamps at high rates pushing high voltage by ac. if the unit is less than 10 years old the lamps are most likely not the problem.
POLAROID 40 Flatscreen
If there is a problem with the backlight inverter. the powersupply it goes into the security mode after start after a few seconds if there is something wrong .example image
Nov 20, 2015 | Polaroid Televison & Video
SCREEN TURNS ON FOR ABOUT 2 SECONDS THEN GOES DARK, FLASHLIGHT SHOWS SCREEN IN BACK GROUND, IT DOSN'T WORK ON ANOTHER COMPUTER,I'M USING ANOTHER MONITOR, IF THE PROBLEM IS I DIODE OR RESISTOR.SHOW WHICH...
This type of failure is usually the backlight inverter power supply. We have an article posted on our site at: http://www.ccl-la.com/blog/index.php/capacitors/ that explains what normally goes out and what needs to be replaced to do the repair. If you would like to post a few pictures of the boards in your unit to our forum section at: http://www.ccl-la.com/forum/index.php then our techs will contact you and guide you thru repairing the unit. If you don't want to do the repair yourself we do offer a repair service, that info can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Screens goes dark after 3 seconds
Your power supply probably has a blow electrolytic cap on it.
You need to pull the power supply board out and have someone replace the electrolytic caps on it. Believe me....if the one for the brightness is bad...they are all suspect!
Caps are cheap...but knowing how to open the monitor and do the soldering is the part that takes some skill and may be costly.
Good luck and be careful.
Mar 10, 2010 | ViewSonic VX1935wm LCD Monitor
Proview monitor PL926WSi Screen goes out after about 5 seconds
Hello Joe,
A red or pink coloration on the screen indicates bad backlight bulbs. They are just like standard fluorescent bulbs just much smaller. When they start failing they light up with a pink color and that will make the screen look pink or red. You can change them but it may not be worth the trouble. You can do a Google search for compact fluorescent tubes and check prices.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 18, 2009 | Computers & Internet
Screen is dark
your backlight is out and one of two things can cause this . 1 being the invert board is failing, or you have a couple of bad caps in the power supply. you can see the bad one they look like little cans , the bad one will have puffy tops on them ...if you see them change them or have it done if not them you will need the inverter board serviced or replaced
Sep 22, 2009 | BenQ DV3080 30 in. LCD Television
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Dell Dimension 4700 won't boot properly.
Disconnect the hard drive and the floppy drive cable at the mother board. The retry POST and try to clear up any problems in POST. If this works fine then the floppy drive cable is either reversed at the unit or the hard drive is jumpered wrong.
Apr 04, 2009 | Dell Dimension 4700 PC Desktop
LG L1715S TFT power issue
Change out C202- 680 uF 25 Volt electrolytic capacitor. Replace with 25 volt or higher. Observe proper polarity when replacing cap: (-) goes to the side with the black mark, check old cap before removing it to see. I just fixed the same monitor today.
Dec 04, 2007 | LG Flatron L1715S 17" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
975 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
