Samsung TXM3297HF You responded to one of my posts regarding my television. When I turn it on, the light blinks, and the unit shuts off after a few seconds. Best I can tell, this is the blinking order: (this is after the power on melody) On for 2 seconds Off for a split second On for 2 seconds Off for a split second On for 3 seconds Off for a split second And then back to solid on as what happens when the unit is plugged in but not powered on. It is a CRT. Thanks -Tyler
2 Suggested Answers
A3sthetix
  • 41 Answers
SOURCE: Samsung TXM3297HF shuts off after 2 or 3 seconds
Usually means your TV's lamp needs to be replaced. I'd need to know the sequence of blinking to really determine this.
Posted on Nov 27, 2008
Samsung dlp tv wont turn on, blinks lamp light green and temp light red
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
Feb 03, 2013 | Samsung HLN467W 46" Rear Projection HDTV
Samsung txm3297hf will not start
R 818 is off value or the IHVT needs soldered or replaced.
That's what I have seen...
Call your Samsung Authorized Service Center, they have the SUPPORT of Samsung to fix these faster
Jan 29, 2008 | Samsung TXM3296HF 32" TV
First blinking green light tv would turn on for a few minutes then turn off, pushed reset button and unpluged but problem would continue now theres no sound no picture and just a steady red light. Please...
The red light is indicating the set has shut down for a specific reason. You can dtermine the reason by going to the sets front panel and pressing the menu button and the device/input button both in together and hold for 6 seconds. The light will switch and begin to blink a series of blinks( First number) and pause briefly then blink another number of blinks (second number) then it will repeat that same two digit blink code. Let me know the code and I will let you know what happened to shut the set down. Respond to this same post for assistance.
Aug 12, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Panasonic pt-51hx42 model tv--When i push the power button the set turns on for a few seconds then turns off. it will not turn on again unless i unplug it and then plug it back in and then it again turns...
I have advice: DOES THE POWER LIGHT GO OFF AND THEN BLINK?
This set has a self check feature---the blinking power light should indicate what is wrong------a series of 3 blinks with a pause is short protection---common here.
A series of 5 Blinks means a short on the 140 volt line, more serious than 3 blinks but still fixable.
These sets all have a "SOS" SYSTEM---at least three protection circuits that will engage if something wrong and not allow the set to come on.
Let me know if a sequence of blinks---easy to miss if you do not know about it.
If this information helped you rate this solution as very helpful as I do this here for free.
If you have questions or need advice respond to this posting with a comment.
REGARDS, SD TECH
Aug 12, 2010 | Panasonic PT-51HX42 51" Rear Projection...
TV picture won't boot
How many times does the Power light Blink as thats a error code. Respond to this same post and I will assist you with the possible cause of the problem.
Dec 22, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Nov 27, 2008 | Samsung TXM3297HF 32" TV
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Sep 10, 2008 | Samsung TXM3297HF 32" TV
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
TXM3297HF Samsung TV shuts Down
Hi!! Kindly check the power supply section if their is a defective resistor or semiconductor device..thank you.
Jan 29, 2008 | Samsung TXM3297HF 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
