Question about Brinkmann 815-3786-0 Turkey Fryer
I have a brinkmann fryer and when you light it up and then let go after 30 seconds of red knob..it does not stay on. What am I doing wrong?
  • 2 more comments
  • joelle123 Nov 27, 2008
    help!!!!! turkey ready and no ignition!
  • Anonymous Dec 27, 2008
    My fryers heated up to about 250 and would shut off by itself. It would not stay on by itself after attempting to relight.
  • kstatham Apr 27, 2009
    Same problem... the red button allows the gas to flow... instructions say to hold it down for 30 seconds, but that doesn't prevent the flame from going out when the button is let go.
  • rustychery May 11, 2010
    I have one also not aware of any red button just turn the valve on
2 Suggested Answers
  • 1340 Answers
SOURCE: I bought a Brinkmann Turkey
If that is what the directions say to do,hold for 30 seconds and it will stay lit and it doesn't,I would say maybe the gas valve is not open enough,since there is fire that's probably not likely because even if there was a little,it should stay lit.Is there enough air ventilation around it?I am pretty sure you do so I would say take it back and exchange it.Fire 101=air,combustible material,ignition.If you have done everything by the book more than 1 time and have nothing still,it is faulty.After 30 seconds,that is plenty of time for the gas to reach where it needs to,that is why they say 30 seconds.
Good luck! Greg
Posted on Aug 24, 2010
ftw1952
  • 10319 Answers
take it back. it has a bad valve which is unsafe to use or repair
I have a Pitco 35cs that I obtained from a place that was closing. I have hooked it up to my BBQ gas stack and I have no knowlege of how to make it work. I have left it hooked up but won't try to start...
first make sure you have a 1/2 psi regulator. If you do, turn the main gas valve to "pilot" and hold it in. The pilot area is behind the burners if you're kneeling in front of it (has kind of a Y shape). while continuing to hold the knob in try to light it every few seconds until it stays burning. keep holding the knob for about 30 seconds and slowly release it. the pilot should stay lit. turn the knob to "on" and set you're desired temp from the TSTAT.
Nov 16, 2010 | Pitco Frialator 35CS Deep Fryer
We r trying to start our fryers.. we were given them and to assistance to start them.. These are gas and we don't have the model number
On the gas valve there is a knob that has 3 positions...ON/OFF/PILOT. Put the knob in the pilot position and push the knob in and light the pilot while keeping the knob pushed in. After about 30 seconds let go and the pilot should stay on. Then turn the knob to the ON position and set the thermostat.
Tom
Aug 11, 2010 | Pitco Frialator 35CS Deep Fryer
How do you re-light pilot light
Turn the knob on the gas valve to the pilot position. Sometimes you have to slightly depress the knob to turn it..don't use a pair of pliers. In the pilot position.. push the knob in and light the pilot..keeping the knob pushed in for 30 seconds. Let go and the pilot should stay on. Turn the knob to the on position and set the thermostat.
Tom
Aug 02, 2010 | Imperial IFS40 Deep Fryer
Cant get the flame to stay lit after holding the red button
THIS IS FROM BRIKMANN WEBSITE SUPPORTMake sure the tip of the thermocouple is located over the edge of the burner so that it gets hot when the burner is in operation. Also, check all the wiring connections to make sure nothing has come loose. It is also important to use the turkey fryer with the pot that comes with the unit. The pot must sit on the spring loaded temperature switch in order to determine the temperature of the liquid in the pot.
Jun 23, 2010 | Brinkmann 815-3786-0 Turkey Fryer
Searing Unit Keeps Cutting Out After Release of Knob
First I have a couple of questions for your question on how to fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free: (800) 468-5252
Local: (972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 10, 2010 | Brinkmann Stainless Steel All-In-One Gas...
I have a brinkman gas grill model 810 8501 s and the searer will not stay burning unless I hold the knob in. As soon as I let go of the gas knob the searer goes out. Any ideas on how to fix?
First I have a couple of questions for your question on how ti fix your Brinkmann Gas Grill, Model 810-8501-S
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
Hope this helps!
Apr 06, 2010 | Brinkmann Stainless Steel All-In-One Gas...
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Brinkmann 815-3786-0 Turkey Fryer Logo
257 people viewed this question
Top Brinkmann Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Brinkmann Kitchen Appliances - Other Expert? Answer questions, earn points and help others
