Question about Sharp 13VT-R100 13 in. TV/VCR Combo
Codes for programing univeral remote
Does anyone have the codes for programing a univeral remote?
0 characters
1 Points
Remote doesn't work. have purchased after market units and they don't sync up either? What to do?
Return the tv universal remote where u bought it,get ur money back.If none of the tv univeral romote programming codes on the owner manual codes for ur tv make and model don't even work and don't have any responses for ur tv make and model functioning all.Try website like to buy the tv original remote or a very closed compatible clone one.
Sep 03, 2011 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
How can i find remote control codes for my quasar tv
Three digit universal remote codes for Quasar TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit univeral remote codes for Quasar TV are:
0171 0148 0054 0170 0062 0374 0381 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. NB: Switch OFF and switch ON your TV, WITH ITS FRONT PANEL POWER CONTROL SWITCH, each time before trying an other code.
Feb 23, 2011 | Quasar VV-1301 13 in. Combo
Remote Code for Comcast DVR
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
I have an emerson ewc20d4 tv/dvd combo without a remote and I can't find a code that will work with my univeral remote? Is there a solution or do I have to buy an original remote?
You would be better off with the original remote. Even if you found a universal that would program to the set some function or another would be missing. Emerson has always been picky about there remotes. Go to and put in your model number. I saw that they had one. Thanks
Oct 26, 2009 | Emerson EWC20D4 Combo
Lost remote to sylvania combo tv how can i change the channel manually?
If tv is programmed you should be able to change channels at the tv front control panel. Also, you can buy a univeral remote and program it to your television.
Apr 23, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I need a Code to Program my Panasonic PV-C135 2W to work my
code should be in the owners manual -- if not -- you can download one online ==
Feb 27, 2009 | Panasonic PV-C1352W 13 in. TV/VCR Combo
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Panasonic TV/VCR Remote Problem
Hold down the play/repeat button on the TV itself for 5 seconds. That toggles in and out of demo mode. ;)
Nov 17, 2007 | Panasonic PV-M2048 20 in. Combo
AIWA VX-T1420 Setting Channels
No it should not light up. If you can not go into menu and add channels manually or auto program. Then you will have to get a remote to work. You could order original
Sep 23, 2007 | GE 13TVR60 Combo
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
18 people viewed this question
Top Sharp Combination Televisions Experts
matt martin
matt martin
Are you a Sharp Combination Television Expert? Answer questions, earn points and help others
