Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washer/drier tripping rcd!
The machine is tripping the rcd on the fuseboard on either the washer or the drier settings. My thought was the element or motor. I guess the motor is commpn to both but is the element the same or are there two?
Many Thanks
  • Hotpoint Master
  • 3,463 Answers
Hi.
Sounds like you have a short or an earth fault.
if it trips right away, try it with the motor disconnected, if it still trips then you will probably have to call an engineer..
Posted on Nov 27, 2008
Problem(s?) Bosch WFO2864GB/01
check the 13a fuse in the plug if you have a heater fault it may well have taken the fuse out as well as the rdc the machine will also need checking to resolve the issue rcd's are very sensitive with most having a trip current of only 30Ma although the heater is first thing to check
Mar 03, 2014 | Bosch Washing Machines
My Hotpoint ultima super silent dishwasher blocked in the night and tripped the fuseboard. I have cleared the blockage but whenever I turn the mains back on it keeps tripping the fuse before it can resume...
also check for a burned heating element, once you locate the element in the lower dish washer look i over for damage , you could also remove the wires from the lower element and then try ad see if it works ifthe unit works
replace the element
you have a short somewhere just trying to eleminate some items
Oct 31, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Dec 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Indesit WI101 tripping Electric RCD
try running with the element disconnected and the wires taped up. usual cause is the element down to earth.
try same procedure with the motor disconnected
Nov 26, 2008 | Zanussi WJS1397W Front Load Washer / Dryer
CDB115
should be a reset switch on the back of the machine usually just a red button or small hole if not there is over heating protection on the heating element or elements if it has 2 heat settings ,but these cannot be reset have to be renewed
Oct 05, 2008 | Candy CNW156 Front Load Washer / Dryer
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
Hot point washing machine WMA 32
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Feb 28, 2007 | Hotpoint WMA32 Front Load Washer
Tripping out RCD
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Aug 25, 2006 | Indesit 24 in. D63 Free-standing...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
440 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
