Question about GE 29267GE3 Telephone
GE Profile XL44 Spectra gas oven
Yesterday I put the oven through the self-clean cycle and it seemed to run fine. I pressed self-clean, the display showed 4.00 hours, I hit start and off it went. The display then showed "oven clean/locked door", and the timer ran down from 4.00 hours. When the cycle ended 4 hours later, I had a clean oven, however, the locked door display would not go off. My husband managed to get the door open, but now the oven will not work - bake or broil. When I try to select the bake or broil function, it will not allow me to set the temperature. The range top burners all work. The door opens and closes and appears to latch properly. I set it to run the self-clean cycle again, and the display showed all of the appropriate messages, however the oven door did not lock. I stopped the cycle after about 10 minutes. Probably important: about 1 year ago I had food placed too close to the broiler and the oven caught fire. It was quickly extinguished, but ever since I turn on the oven to bake or broil, the top of the range gets hot - hotter than it used to. It is almost too warm to the touch, as if I burned through the insuluation. I have not put the oven through the self-clean cycle since the oven fire - until yesterday. I have been baking and broiling without incident until yesterday. I have the same problem but no numbers to press help me my stove dont work and everytime i try to get it ti work it saying "F1" what is the problem????
CORDLESSGURU
  • 106 Answers
SOURCE: Only shows the number 1
You have a short in your button assembly or a bad cpu. If it is not a spill or moisture from something like that you have some serious electrical problems. JennD has some different issues, physical damage it sounds like. Both sound like they need to go in for repair. You can google cordless telephone repair to find a solution unless your phones are nearly new and you want to try the warranty route. Good Luck, Guru
Posted on Feb 07, 2008
  • 84 Answers
SOURCE: switching from pulse to tone and reverse
once tone/pulse appears there should be a way to hi light/select or choose either one.you must set it into memory. after it is stored, you shouldn't have to set it again before making other calls.
hope this helps
wg
Posted on Feb 11, 2008
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
SOURCE: GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Posted on Jul 20, 2008
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Posted on Feb 28, 2010
How do you turn off the self cleaning oven when door is locked on the GE Spectra XL44
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE 29267GE3 Telephone Logo
56 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
