Question about LG Flatron L1512S 15" LCD Monitor
Monitor just goes off after a short time
I have a Emprex LM- 1704 TFT LCD Monitor which just goes blank after a short time running. However if I power off/on it will restart but again go off after aprox 2mins. when it is working the picture is perfect, This seems to have started after being switched off for a week while I was on holiday.
I have tried to take the unit apart but although I've taken every screw in sight out it still does not come apart easily & seems prone to breaking if I try to force it
can you please offer any help or at least point me in the right direction to an answer ?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
There's a setting on the computer to turn that on and off...in setting s
Posted on Apr 26, 2017
  • 16 Answers
SOURCE: 17"LCD Monitor
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area.Check this link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
likha
  • 790 Answers
SOURCE: Monitor won't light up. Only just for a second or two.
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Posted on Mar 06, 2009
  • 415 Answers
SOURCE: screen dead
since it's only 3weeks old as long as you have the receipt take it back .
Mark
Posted on Apr 18, 2009
RohitChauhan
SOURCE: Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Posted on Aug 10, 2009
  • 732 Answers
SOURCE: ho w to open the emprex lm 2203 monitor
jerry932, If you still have problem removing back cover form the front bezel after viewing some of the longer, more detailed video clips at YOUTUBE under "LCD monitor dissassembly" and "LCD monitor repair" we will try to help you. Also try www.ccl-la.com/badcaps.htm for ideas on how to "get inside". Dam, I wonder why everybody on the planet wants to open up their monitor's? Is there a problem out there??? Wow!!
Bye for now. 12fixlouie
Posted on Feb 20, 2010
Does the embrex lm 1704 monitor have a vga?
Show 'maximum SXGA'. Contact them and ask, but it would be a waste to run it on VGA when its capabilities are better. http://www.emprex.com/02_products_02.php?id=150
Oct 01, 2015 | Computers & Internet
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
2 year old exprex mointor went bang and is now not working, why?
Contact the store that sold it to you.
It may still be under warranty.
If not, then the internal power-supply has "popped".
It's probably cheaper to replace the whole monitor than it would be to repair/replace the power-supply.
May 07, 2010 | Office Equipment & Supplies
Ho w to open the emprex lm 2203 monitor
Feb 20, 2010 | Emprex LM2201 22" LCD Monitor
Emprex monitor lm 1905 - blacks out after a
If this has an internal power supply (no external brick) then you probably have failure of the capacitors inside. The problems exhibited by these failures are usually summed up as "works for a short while and quits" or "will not come on". Yours is probably similar to some Gateway monitors that I have repaired, The parts required for the repair should be under $10.00 and should take under an hour. Now you need to find a shop that can and will do the work unless you have soldering skills.
Dec 05, 2009 | Emprex Computers & Internet
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
LG Flatron L1512S 15" LCD Monitor Logo
69 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
