Question about WYSE Winterm 3350SE Network Terminal
Winterm model #3350SE shuts down randomly
The winterm will power down randomly from time to time. Tried looking for a pattern but it appears to be totally random.
Perhaps over heating problem?
These things are convection based cooling. The bottom and top both need to be very clear of obstacles. I seen one in use at an office, and the person had it sitting next to file organiser, she continually placed files on the top of the wyse "because she could". It took a week of constant shutoffs for it to sink in that it needed to be clear of stuff.
Posted on May 03, 2008
SOURCE:
Ho do the wyse winterm s50 worck? and ho do i, or can i use the?
There is documentation available for free from the wyse website on the knowledgebase. This will detail the full usage of the S50.
It can be used as a local web terminal, or linked to an external server, via RDP (terminal services) or ICA (citrix).
The admin guide (from wyse.com) will help you figure this out :)
Mar 24, 2009 | WYSE Winterm S50 Network Terminal
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Website has blinking pages on some computers and not others?
Greetings myname is Mark and I will be glad to assist you. What is happening on your friends computer is what is called the refresh rate there are several issues that cause this but it generally narrows down to the router and the hosting service he is using and their security settings I suggest this.Have him go to the website then go to tools in the right corner go down to internet options and in the browsing history click on the settings and make sure where it says automatically it is checked so it will automaticaly store his sites newer pages or altered pages. Let me know if this helps.
Be mucho blessed,
Mark
Oct 30, 2008 | WYSE Winterm 3350SE Network Terminal
Wyse 3150 terminal - yellow light
Does it boot into BIOS if you hold down Delete while powering up the terminal?
Sep 03, 2008 | WYSE Winterm 3150SE Network Terminal
Problem with WYSE Winterm 3235LE
Tsaukpaetra is correct it's a resolution mis-match with the monitor you are using. If you have Rshadow loaded on the winterm you can VNC into it and change the resolution. If not you can hold down the letter "G" on the keyboard to perform a factory reset.
Aug 29, 2008 | WYSE Winterm 3235LE Network Terminal
Reconfigure winterm
try holding down the 'g' key when booting -this just worked for me.
Aug 11, 2008 | WYSE Winterm 3150SE Network Terminal
Getting connected
Build a Windows server with DHCP and DNS and install Terminal Services. Open config on the winterms and setup the RDP client. Follow the prompts, it's pretty straight forward.
Term Service requires license after 90 days AFAIK, so you better have a plan by then.
Thats the easiest way to setup and connect, it is a far from complete solution, though.
I would suggest you google upgrading the winterm firmware using FTP, the older firmware is poor and slow.
Otherwise, these are great little termianls that will last forever and work well.
Mar 17, 2008 | WYSE Winterm 3350SE Network Terminal
3350 power connector specs
The Pin Assignment is as follows:
Pin 1,4: +5V
Pin 2,3: not connected
Shield: Ground
The AC Adaptor is specified as 5V , 4Ampere. Actually the unit draws around 2-3 Amperes.
/ 3 1 \o
\ 4 2 /
This "Image" shows the pins, when you look onto the jack at the back side of the terminal, with the terminal standing upright. The label = 5V is located left of the jack
Jan 20, 2008 | WYSE Winterm 3350SE Network Terminal
Unusual problem
Perhaps the systems have accumulated dust on the inside, and therefore the unit could be overheating.
Oct 16, 2007 | WYSE Winterm 3235LE Network Terminal
WYSE Winterm 3350SE Network Terminal Logo
199 people viewed this question
Top WYSE Computers & Internet Experts
Archie Ferrarini
Archie Ferrarini
Daniel
Daniel
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
