Question about Nikon D40x Digital Camera
Nikon D-40X Lens LOCKED UP???
I have a Nikon D-40X. The camera has never been dropped, kicked, etc. You can rotate/adjust the lens through only part of the cycle, and the part of the lens that extends out the furthest is floppy/loose. HELP!
  • michael galang May 11, 2010
    there is a switch on the front left side of the cam. turn it to A or 'auto' focusing. does the end stil turn freely?
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Posted on Mar 24, 2008
  • 102366 Answers
SOURCE: hi everytime i try to turn on my nikon s210 the
This is probably THE most common failure among digital cameras, and it can be caused by dirt, dust, grit, or dropping, among other things.
There's a halfway chance of fixing it yourself, described here:
Posted on Feb 14, 2010
  • 11967 Answers
SOURCE: My Nikon L18's lens is extended half way and
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 19, 2010
lock123
  • 6831 Answers
SOURCE: The camera is Nikon S3000. It was dropped with the
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 08, 2011
Unable to remove lens - does not rotate completely
Did you press the lock/release button complete and did you hold it till the lens was rotated complete? You know the lens with Nikon goes the other way as with Canon?
Looking to the front of the camera you have to rotate the lens clock wise on a Nikon. Counter clock wise on a Canon.
Sep 05, 2013 | Nikon D3000 Digital Camera
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for my Nikon D40. When the lens is attached the settings get locked on MF. Is there anything I need to adjust to fix this problem? Charles
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
Sep 02, 2010 | Sigma 70-300mm f/4-5.6 DG Lens
Nikon AF-S DX 12-24mm grinding noise
sand or dirt may get inside your lens or may be you or or someone drop it. send to nikon for cleaning cost 50-70 bucks.
Mar 18, 2010 | Nikon AF-S DX 12-24mm f/4G IF-ED Lens
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Using old lens on new Nikon digital cameras
The short answer on both is Yes, but with limitations.
The longer answer can be found here: Nikon 40x
Mar 26, 2008 | Cameras
Nikon Coolpix L12 It has a constnat lens error screen
mine has that too....urgh i need to take pics cuz im going on vacation too....joy
Dec 31, 2007 | Nikon COOLPIX S9 Digital Camera
LENS ERROR
buy a new camera ya idot
Dec 03, 2007 | Nikon COOLPIX L3 Digital Camera
Canon lens 18-55mm for canon rebel xt
New lens is on the Horizon here I guess any repairs will be costly
Aug 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
Nikon D40x Digital Camera Logo
158 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
