Maytag 22.1 cu. ft. Bottom Freezer Refrigerator w / Factory Installed Ice Maker Logo
Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inside of refrigerator isn't cold and ice on top of freezer door
Is visible. what is wrong with it?
  • Ron Buice
    Ron Buice May 11, 2010
    Need more information on this problem
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 311 Answers
  • Posted on Nov 28, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
311
Questions
0
Helped
81528
Points
758
Is fan running in frzr? IF not, then it is bad and needs replacing. Common issue.
1helpful
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
1helpful
Frigidaire Refrigerator FFTR1814LW bottom fridge not cooling properly 50 degrees. The top freezer is rock soild Thx
That is the classic symptoms of a defrost system failure. Suggest you look behind the rear panel on the inside of your freezer and see if it is iced up. If it is then it is a defrost problem which could be the defrost heater, defrost thermostat or defrost timer. If it isn't iced up, then check to make sure the fan is operating. If it isn't then it won't push cold air out of the freezer into the refrigerator section.
There's ice builds up inside the air circulation vent from the fridge side. This make less air coming from the freezer to the fridge, and the fridge is not getting cold, sometimes there isn't any...
you may have a seal problem on your doors make sure all seals seat to the fridge body properly, I suspect moist air getting in the fridge or someone putting hot food in it after supper :-)
1helpful
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
2answers
REFRIGERATOR FREEZER SIDE ICEING UP
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Refrigerator and freezer not cold also inside of freezer wall ice is formed. What could be the problem ? Please help.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
GE TFX 22CR Freezer works but not Refrigerator.
If the evaporator fan isn`t working, the frig will not circulate the cold air needed from the freezer to the fresh food compartment. You will need to remove the panel and check for ice around the fan. Make sure it can turn free. If it isn`t blocked and you can turn it freely and there is voltage going to it, the fan motor has gone bad and needs to be replaced if there.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
