ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
SOURCE: Olympus SP-350 USB Device Not Reconized
Hi
You have to take out the card before you switch on the camera. Switch on the camera and then put in the card. Then it works
SOURCE: Cannot download pictures from camera to computer
Sir,
First uninstall the software and try to reinstall the software with by manual follow instructions.
Link 1
Thanks
Good Luck
Appreciate to rate as "Fixya"
SOURCE: computer won't read card through usb cable or card reader
Try using a separate card reader to download your pictures to a folder you create on your desktop.
SOURCE: Cannot download pictures to computer
check your device manager on the computer to see if your if your usb driver are loaded and have no conflicts, u could also have a bad cable don't load the camera software on to the computer if you did uninstall the software from the PC and then plug the camera in and let windows recognize the camera if this does not work change the cable your using, GOOD LUCK
