SOURCE: 1998 cadillac seville STS
on my 1998 Deville its located in the trunk. the panel thats is butted up to the back of the rear seat. look for some black nuts around the top of rim of the trunk, they are about 1'' long, these have to be removed first... good luck.....
Mac.........
SOURCE: I need fuse box diagram
Goto this website wiring-diagram.com They have full color factory wiring diagrams.
It does cost a few bucks. Not to bad though.
SOURCE: 1998 cadillac seville sts air ride prob
Disconnect the - battery terminal for a minute and reconnect.
Good Luck
SOURCE: I need a cadillac seville sts 1998 4.3L & 32
Try Item #1 first it is the easiest.
Then Check the small water pump belt, it is not the serpentine belt.
The next step is to either check the Block with the following block tester available from NAPA
The part number is 700-1006
or change the thermostat dealer cost about 60.00 AUTOZONE about 40.00 You will need to purchase the Gasket with which ever you purchase from.
I had written a detailed note and the system dropped it. I hope this helps. coolant system drawing is available from:
http://media.photobucket.com/image/coolant%20system%20cadillac%20sts%201998/Parallax1/NSCoolingSystemCircuit.jpg
