Question about M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card
Mobilepre usb makes sound on vista go warped speed
When i install the mobilepre usb on my new dell inspiron 1525 laptop windows vista thhe sound goes warped speed in itunes when i play back music and the actual computer sounds are playing really really fast. and then when i unplug or uninstall the driver it goes back to normal.
any help? ive had this on my old dell 4700 deskpt it worked perfectly
  • famousdrumer Nov 30, 2008
    yes and yes the sound still goes warped speed. in itunes AND the windows sounds(turning off the computer, closing a page, minimizing a window, ect.)
    but if i turn the computer on and leave the mobile pre unplugged and plug in back in after windoows starts the sound is normal but i cant control any volume or the mic level inputs i cant mute or lower are raise the sound when this happens
  • famousdrumer Dec 01, 2008
    the driver didnt work eitehr
  • 1,879 Answers
If you are going to uninstall the device driver, do it from the Device Manager first then from the Add & Remove Programs.
Reboot
Install manufacturer provided driver before connecting the device as Vista will load an incorrect driver.
Posted on Dec 01, 2008
  • 162 Answers
Vista has a mind of its own and always loads incorrect driver (in-box - Microsoft provided).
Uninstall driver, Disconnect device and reboot computer. Install the driver from manufacturer first then plug the equipment.
  • 1,800 Answers
Hi.
the problem is too easy to solve, u ve a conflict of USB bus:
follow me:
1/ uninstal itunes.
2/ unplug the amp.
3/click here to download compatible drivers for vista
4/ reboot computer .
5/plug it always in the same usb port.
6/ enjoy it.
rate me plz
    Sergeant:
  • 237 Answers
Here is the driver for mobilepre usb for a windows vista 32 bit. http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=6&PID=8eb1a9920df341303f81bca7ff458be3&OS=45#tabs If you need one for a service pack 1, you can select it from the menu as welll.
This driver is the most updated from august 2008.
Also download the newest version of iTunes.
    Novelist:
  • 166 Answers
Uninstall all the drivers and then reinstall.
Posted on Nov 30, 2008
  • 340 Answers
if its as old as all that, maybe a new driver would do the trick, download from here:
http://www.m-audio.com/index.php?do=support&tab=driver&PID=8eb1a9920df341303f81bca7ff458be3&serie_ID=6#tabs
regards
/Teis
    President:
  • 1,952 Answers
Uninstall other audio software and try to install each audio software one at atime and test it out before install another software
Posted on Nov 28, 2008
  • 102 Answers
You are running it with the wrong drivers. There are updates availible to fix this . Also you might need to remove your other sound drivers. Hope this helps
  • 728 Answers
Try this: Go to the start button, go to settings, look in the list and click on the control panel button, click on sounds and audio devices button, and under the menu, you will need to set the tempo/speed of sounds coming through the mobilepre. Then you need to save your settings. It should work regularly then.
Posted on Nov 27, 2008
  • 96 Answers
Hello there. It sounds as if there is a sample rate issue. here is a link to the driver download page. Please take note to the vista, and vista sp1 options. download both and see which one (if either) works. There should also be a section in the device controls the manually adjust sample rate inputs. you may also want to insure that your audio card is configured properly to manage the audio coming from the preamp.
  • 4,806 Answers
What it is, is just the media player you are using, lol, i get this problem all of the time and you dont have to worry, its nothing to do with your external drive, you have 2 choices.
1 - reinstall itunes and try again
2 - try playing your music in a different media player like Winamp for example
regards
  • Lee Hodgson
    Lee Hodgson Nov 30, 2008
    did you try the codecs i advised you install and did you try a different media player?
  • Lee Hodgson
    Lee Hodgson Dec 01, 2008
    I think you have to face the fact that the device is not compatable with vista.
    In my exprience with these "so called" vista compatible drivers, they don't allways work well.
    Have a look and see if there is an updated driver for the mobilepre usb or run it in XP mode
    regards
  • 734 Answers
This is a problem of driver clashing.
  • 1 more comment
  • futureloginn
    futureloginn Nov 27, 2008
    First install the driver for mobilepre usb and then install your sound card driver that will fix your problem
  • futureloginn
    futureloginn Nov 28, 2008
    Thanks
  • futureloginn
    futureloginn Nov 30, 2008
    ok, download kodak for this problem and install to your computer that will sure fix your problem.--------
    http://www.free-codecs.com/MP4Cam2AVI_do...
  • 19,396 Answers
Ensure that the unit is installed with the proper drivers, try reinstalling drivers.
  • Ginko
    Ginko Nov 27, 2008
    There is an issue with mobilpre and Vista.
    If you connect mobilpre to a Vista computer, the system will automatically install the wrong driver for the device.
    Plug the Mobilpre to one of the USB ports and then reinstall the driver, downloading the software from M-Audio website here.
    After you do this, you need to plug the mobilpre always to the same USB port, or Windows wil reinstall wrong drivers again.
  • Ginko
    Ginko Nov 30, 2008
    Did you reinstall the driver software, not Itunes, you need to reinstall the driver, downloading the software from M-Audio website here.
    This is normally the fix for this problem, Itunes has the driver for the Ipod not for Mobilpre.
    Reinstalling Itunes has nothing to do with this, is a wrong solution.
    Reinstall driver from reinstall the driver, software from M-Audio website
I have an inperion 1525 and after i reinstalled windows vista home premium, the internal speakers stopped working
It sounds like a driver issue. Go to http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs and enter your service tag. It should give you a list of available drivers for your system. Make sure that it specifies Windows Vista in the drop down menu. Check for audio drivers and install the most recent one.
Feb 08, 2011 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 xp supported all free softwere
dell laptops running in windows xp and vista can install any free software as long the software is windows based like xp and vista.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to...
If your laptop is still under warranty, installing WinXP will void the warranty. It's very tricky. I'd suggest getting another PC with Internet connection and search and download drivers as needed for your 1525. Good luck.
Jun 13, 2009 | Dell Inspiron 1525 Laptop
Want to get Dell inspiron 1525 drivers for window xp
http://www.laptops-drivers.com/dell-laptop/how-to-install-windows-xp-on-dell-inspiron-1525-or-downgrading-vista.html
hope this will help
Mar 03, 2009 | Dell Inspiron 1525 (dndwpa3_6) Intel Core...
SOUND DRIVER PROBLEM IN DELL INSPIRON 1525
Reinstall the xp audio drivers off of Dells website.
Thank you for choosing Fixya.com
John C.
Feb 18, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Download win xp
sorry u can't download windows XP u should purchase it and remove vista and install windows XP after installing u should download drivers for the dell laptop Inspiron 1525 of windows XP because vista is pre installed operating system including with drivers
Jul 29, 2008 | Microsoft Windows XP Professional With...
Xp Drivers for Dell Inspiron Laptop 1525
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
Open Questions:
See all M-Audio Mobilepre USB Bus-Powered Preamp and Audio Questions
M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card Logo
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
