Question about HP PSC 750 All-In-One InkJet Printer
HP PSC 750 - Gives message - check cartridge or wrong cartridge..
Recently I had a serious operation and was out of commission for more than two months. During this period my printer was not in use. The cartridge I had been using successfully is the same one invoking the messages above.
The command, "PRINT" causes an error message - wrong cartridge. Putting a new cartridge in - DITTO. Also the test did not print automa- tically. I ran the "SELF-TEST", and it printed a blurry test with false colors.
Would cleaning the heads help? If so, How?
thanks martin smith
  • 57 Answers
You could try to clean with alcohol the metalic looking part of the cartridge. If this doen't work, you should replace it and try a new one. I would suspect the the ink has dried on the cartridge and is clogging the jets. .
Posted on Nov 27, 2008
The printer give message align cartridge, eventhough already done couple of times....
Have you scanned the alignment page if no then do it. After that also if it gives you message then you can ignore that.
Feb 16, 2011 | HP PSC 750 All-In-One InkJet Printer
My printer has decided that the black printer cartridge that has worked for months is the "incorrect cartridge". Figured it was a software problem, since my other printer now gives the same error...
I am having the same problem, I tried to replace the black cartridge and now it says it is the incorrect cartridge, so I put the old one back in and get the same error message.
Feb 09, 2011 | HP PSC 750 All-In-One InkJet Printer
Psc 750 was just fine & making beautiful copies, then it started saying the cartridges are wrong, I replaced cartridges & still the same message,
try to wipe the electrical contacts on both cartridges with damp tissue. If you find any ink on the tissue, also clean the corresponding contacts in the printer.
Install the cartridges back in and once clamped in, move each around slightly (from side to side).
Close the lid and see what happens. If still no joy, have the printer serviced.
hope this helps
Nov 30, 2010 | HP PSC 750 All-In-One InkJet Printer
I have a hp psc 750 and have just put a new black ink cartridge in and keep on getting the error message wrong black ink cartridge
Did you make sure you removed the plastic tape protection before installing the cartridge? Check to see if there is anything on the bottom of the unit. It could be the problem. Check the install instructions.
Feb 01, 2010 | HP PSC 750 All-In-One InkJet Printer
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
183 people viewed this question
Ben Johnson
