Question about Foxconn K7S741GXMG-6L Motherboard
Foxconn K7S741GXMG-6L Sound issues
Have anybody had this issue before?? Purchased about 2 or 3 of this boards before no issues except the last one, has been loosing the sound, started with the buil-in went off, did a clean install no luck added a 2nd sound card (SB Live) from the stash worked great for about a month, and back to the same issue, 3 sound cards later we purchased an X-FI and decided to pull the board before frying this one, while pulling the board I had installed a Floppy/Media reader conected to USB Headers on MB, when I unpluged I noticed the cables were melted, conection was fine, is the type all the USB wiring is built-in into one conector and only fits one direction. Decided to give one more shot before contacting Foxconn jut the basics, same problem. Any Ideas!!
  • 102 Answers
Maybe the problem isn't in the sound cards or buil-in sound cards, i'm sure it's the speaker your are using, it may have some power leakage or something of that sort... check your electric "ground" connection too.
Posted on Jan 27, 2007
SOURCE:
Motherboard is not powering on and generates heat from the power supply
Sounds like a faulty power supply... Time to replace it! :)
Also, read this tip of mine to find out more possible causes to your probem.
Regards,
Pelu.
Jun 28, 2010 | Foxconn K7S741GXMG-6L Motherboard
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
FOXCONN K7S741GXMG-6L
AMD 2800+ is 333MHZ while
AMD DURON 120MHZ is just 200 MHZ
It means that the board supports 333MHZ not 200MHZ.
Well it's not compatible...
Jan 27, 2008 | Foxconn K7S741GXMG-6L Motherboard
Post issue
I can't get Foxconn's website to pull up ATM, but I had this sort of issue once before, and felt completely stupid once I figured it out, and this is going to sound strange, but, remove your CPU fan and try to power up. If it does power up, then your CPU Fan is shorting out the system. If that doesn't fix it, then it is possible that your processor is not supported by the motherboard.
Hope this helps!
-Backu
Jan 15, 2008 | Foxconn K7S741GXMG-6L Socket...
Dead board.
He is refering to this posting: http://www.fixya.com/support/t128900-mobo_no_boot_after_changed_power_supply
Jan 01, 2007 | Foxconn K7S741GXMG-6L Motherboard
Foxconn K7S741GXMG-6L Motherboard Logo
96 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Thomas F. Schneider
WTF Chuck.....
WTF Chuck.....
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
