Question about Viking VGRC485-6 Gas Kitchen Range
Problems with my oven, I need the electrical drawings for the oven for model vgrc485-6qdss, my range is located out of USA and I do not know how to get this drawings
  • 59 Answers
If you pull the unit out of the opening, the rear cover should have the wiring diagram on it.
Posted on Mar 11, 2009
No part of this range will come on after mishap with oven light assembly
There a electric drawing behind cover were the knob or touch screen check drawing for fuse if I know what oven it was would help but be sure to un plug stove for electric supply before doing check please.
Jan 14, 2014 | Kitchen Ranges
Oven will not light the stove top lights but not the oven electrical ignition
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 28, 2011 | Whirlpool SF111PXS Gas Kitchen Range
Gas burners work. oven will not light. gas works in oven
Nov 05, 2010 | Kenmore 45062 / 45069 Electric Kitchen...
Our oven does not heat-the broiler and the range do work but the oven doesn't get hot. Is this a pilot problem-and if so how do we re-light it?
is it gas or electric?if it's gas and the broil works but the bake doesn't you need to change out the ignitor,ovens are electronic ignition now and you don't relight them unless you know there is a pilot,next time send brand name and model number,if there's a storage draw under the oven door,open the draw and look at the frame to the left or to the right of draw opening and you'll see a tag with the model number,most likely all you need is an ignitor,pull out the racks and remove the bottom panel and you'll see the ignitor next to the burner tube,when you put the oven on bake the ignitor should glow red and ignite the flame in less than a minute most times less than 40 seconds,if it doesn't you need to change the ignitor.when you go to remove the screws that hold the ignitor on wet the threds with a wet paper towel and the screws will come out easier than if they were dry
May 13, 2010 | Ovens
Mer5755 Oven losses temp. Start at 400 loses temp later
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 02, 2010 | Maytag MER5755Q CleanDesign Electric...
Oven Problem
I would look at the transformer and verify that it is jumpered ( hooked up ) for the correct power source.
If there is an option to add a inline fuse to the transformer this will limit the amount of damage to the transformer so you can veirfy the issue.
If you know the current draw on the circuit, you can verify to see if the transformer is sized correctly to supply the power to the unit.
Dont know if this is helpful , hope it is......
Jul 17, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Dacor oven will no heat.
dacorservice.com very likely has your answers. Good Luck and Happy New Year!
Dec 27, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Need to Clean
go to fixva.com manuals...your model number is located on top of pot draw on body of range
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Hello, I have a Frigidaire Range stove Model #FGF378WCCD. The oven ignitor heats but the oven doesn't light up and we smell no gas. What can it be?
if the ignitor may glow but if it isn't turning almost white it is not getting hot enough to open valve ,,,,, make sure it glows very bright and if not replace it / larry
Nov 29, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Oct 24, 2008 | Kitchen Ranges
Viking VGRC485-6 Gas Kitchen Range Logo
212 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
