Question about Fellowes S701CM Shredder
Royal Shredder My shredder will no longer shut off after the shredding is done. For the first few months everything worked perfectly, and we were able to leave the shredder in AUTO mode, put paper in it, and walk away knowing it would shut itself off after the paper was gone. Now we have to tend it and slide the switch to off after the paper is gone. I've tried oiling the cutting blades, making sure there are no paper scraps hiding in it, and a general blow-out with compressed air. Is there anything else I could try?
There is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Posted on Apr 18, 2007
My royal 112mx shredder doesn't shut off automatically after shredding a sheet
Unplug the shredder. Either blow with canned air or take a small paintbrush and clean the sensors where you put the paper in. There is one above and one below in the center of the slot.
Feb 28, 2011 | Royal 112MX Shredder
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
Shredder won't shred forward but works in reverse
Either the "eyes" are dirty or faulty, or the pcb has gone. Call Royal at 1-800-524-0799 for parts availability. When you get it working again only run the unit at 70% of its max rating... this provides less stress on the motor and internal parts.. the machine will last longer and you will have fewer jams.
Aug 07, 2010 | Royal 80x Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Shredder only operates in reverse
Check and try cleaning the "eyes" in the paper throat... if that dosn't fix it it could be the pcb inside...call Royal at 1-800-524-0799 for parts help.
Feb 17, 2010 | Royal CIA 12X Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
Turns on when paper in slot, but won't pull it through to shred.
must disassemble feeder unit. you will find many bits of shredded paper to pull (push) out with a long narrow tool like a crochet needle.
Jun 19, 2007 | Royal AG10X Shredder
Fellowes S701CM Shredder Logo
292 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
