Toshiba Laptop SPA 10 -WONT START
POWER LEAD OK , BATTERY ASUME OK BUT WHEN PRESSING START BUTTON -NOTHING -THE LED WITH SYMBOL A LEAD FLASHES IN THIS SEQUENCE 5 FLASH'S PAUSE THEN 3 FLASHES PAUSE -5 FLASH'S - 3 FLASHES ETC  ANY IDEAS ?
  • vuduvu Jan 03, 2009
    I have exactly the same problem, when I try to turn the laptop on I get no response at all. The hard drive is not running, it doesn't make a sound. I have tried removing the power lead, removing the battery, beyond that I don't really know what to do, any advice would be greatly appreciated.
  • 4,806 Answers
That just sounds like the hard drive running, try plug an external monitor and see what happends
get back to us
regards
Posted on Nov 27, 2008
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
Toshiba PA3362U laptop wont start up ? My son left it turned on for 10 days without my knowing. I try to start uo but the inly response is alittle flashing light at the front and that stopsafter a few...
Make sure your plugged in and the battery is charged up. Usually the laptop won't stay on for ten days because the battery needs recharging. Press the power button for about 5 seconds then try pressing the power button again to restart what happens?
Jan 09, 2010 | Computers & Internet
SP 6000/PS6000E-207PK-EN Will not fire up. If press start, then LEDs flash Orange (1st left) 5 times then 2, then 1 and then repeats. 3rd LED (green) stays on. If battery is removed, start button pressed...
You got some short on board, You need techguy. Or possible Bios flash, Remove the Harddisk and press the power button.
If nothing change, Remove power, battery, cd rom, Hdd, memory.
Then put one stick of memory, power up, see anything comes up.If does, power off, put the other memory plug in power, fire up.
If does ok. Then plug off, and put hdd without CD rom. see if it did work.
If none is worked as I say you have short or CPU fan is not functioning.
Goodluck.
JMC
Aug 17, 2009 | Toshiba Computers & Internet
Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
Jul 03, 2009 | Dell XPS M1530 Notebook
Toshiba satellite pro 4200 wont start,just 1 flashing amber light
I had a similar problem on SatPro6100. Mine was LSSSLSSL (10010001).
Thinking that the laptop was buggered I decided I would take it apart and have a look at the insides.
Whilst it was apart I also disconnected the BIOS battery.
Couldn't find anything that looked like it had burnt out so put it all back together again.
When I turned it on again the darn thing was working fine!!!
Go figure!!
The whole thing was apart for about 2 hours or so.
I don't know if it was removing the main battery and leaving it out for that time or whether it was resetting the BIOS (by disconnecting its battery) that fixed the problem.
Anyway, I have managed to get all my data off the laptop so not too worried if it screws up again.
I do however always disconnect the power source BEFORE shutting down the laptop and only reconnect it after I have pressed the on button. Seems to be working fine (for now!)
Hope that helps someone out there!
Mar 11, 2009 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
Flashing Charging Light on AC Power
shortage on the motherboard, needs new motherboard.
Mar 09, 2009 | Toshiba Tecra 9100 Notebook
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
