Question about Linksys Wireless-G WRT54G Router
How do I find the PIN number for my linksys WRT54G2 router
When I try to setup my wireless network I am asked the pin number for the router. How can I find this pin number
  • JDTec
    JDTec May 11, 2010
    Is it asking for the encryption key or the use password? The router do not have "pin" numbers
Password problems.
Depending on the type of router, you could have various defaults set, if you never changed them.
You can press the reset button somewhere located on the router itself, using a pen/pin/pencil, and then google your brand of router asking what the default password is.
If it is a Linksys, you could google "Linksys default password" or "Linksys default login" for example.
Dec 20, 2011 | Linksys WRT54G2 Wireless Router
I want to set up my LINKSYS network adapter and my laptop asks for the pin number? where is the pin number?
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.
For information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 28, 2011 | Linksys WUSB11 802.11b Wireless Adapter
My network setup is asking for a pin number that is on my router. Obviously there is no pin number for this particular router and my network is asking for a 4 or 8 digit number. What do I do?
If its asking for a pin number I would check the sticker on the bottom of the router. it may have the router PIN you are looking for. If not trying typing in your internet browser address bar 192.168.1.1 and find the network settings and see if there is a pin set up, if so write it down or clear it to have no PIN
Feb 28, 2011 | Linksys Wireless-G WRT54G Router
Wont allow me to connect 2 additional computers and need pin name or number
Two methods to solve your problem:
Method 1:
(1) Using your currently connected and working computers, access the wireless router security page at 192.168.1.1 (page 8 of 44 from the WRT54G2 manual), default password "admin" (page 7 of 44 from the WRT54G2 manual)
PDF file of the Linksys/Cisco Wireless-G Broadband Router User Guide:
http://belkashop.com.ua/products_files/WRT54G2_V10_EN.pdf
You'll need Adobe Acrobat Reader to view/print this file - free from www.adobe.com
(2) get the WEP or WPA password, and enter it into the wireless LAN (WLAN) settings on your 2 additional computers.
Method 2:
Alternatively, access the WEP or WPA key on one of your working PC, by
(1) make sure the printer is working, powered up and online.
(2) invoke "Network Setup Wizard"
(3) wind thru various steps (click-ing NEXT), then select "Print Network Settings"
(4) use the printed WEP or WPA key in the WLAN settings on your additional 2 PCs.
Jan 02, 2011 | Linksys WRT54G2 Wireless Router
Pin number
you can get the pin number by contacting the provider.
Jun 30, 2010 | Linksys Wireless-G Broadband Router
We just added a second laptop to our home network and in setting up the laptop for wireless it asked for a pin number for our linksys wireless router but the pin number is not on the unit and we don't have...
Yes this is very straight forward
open internet explorer on your computer which is connected to wireless router.
browse to your gateway address. The default for linksys is usually http://192.168.1.1
then it will ask for username and password
linksys default username: (leave this blank)
linksys default password: admin
if that doesn't work try username: admin
password: admin
Once logged into console you should be able to see wireless security settings
Click on that and it will take you through to a page with your security settings on there you will see a wireless key or network key or wireless passphrase.
simply make a note of the key as its written. (If the password is masked or *********** out ) which is the case on some of the newer linksys devices you can simply overtype the password with a new one, bear in mind that you will have to then update any clients that normally connect to the wireless network with the new password. So thats all computers, laptops, DS's Wii's Playstations & Xbox's.
******I'd STRONGLY recommend you DO NOT change the wireless password / security key over wireless you should always do it using an RJ45 ETHERNET cable connected to your computer and the router. *********
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | Linksys Wireless-G WRT54G Router
Router asks for some kind of pin...
I have never heard of such. Sound like your computer is tring to get you to enter the WEP key or Passphase to access the router.
If you don't have a WEP key or Passphase setup on the router then you should just be able to click "ok" or "enter" (with the field blank) and bypass this screen.
Also check your network properties on the computer that is giving you trouble. Open your network connection, right click your wireless connection and click on "properties". Check the tabs and make sure you don't have WEP or secure network highlighted in one of the check boxes.
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
I have had this problem. Go to the website and get the free phone number and ring them. They were able to help me (twice as I forgot after the first time).
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
30,371 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
