Question about Toshiba Satellite A205-S4617 Notebook
Computer isnt running
The computer doesnt seem to be on or off. The power blue light remains on,even when the laptop is closed,even though the rest of the computer isnt on. I tried turning off the power blue light,but it doesnt respond. When the laptop screen is open,The computer will not turn on,or the fans,even though the light is blue.
In other words, the blue power light is constantly one and computer doesnt respond to anything at all.
    Guru:
  • 257 Answers
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Posted on Nov 27, 2008
My laptop is fujitsu lifebook U772 but I recently could not use it . I see nothing pop up after I pressed the on button and the screen remains in black even though there is blue light indicating the...
Shine a light against the screen when you power it on. If you can read anything on the screen then it is a back light or inverter failure. Hook up an external monitor to it if you can and see if that helps show anything.
Jun 30, 2014 | Computers & Internet
After shutdown the blue light remains on
Unplug, remove battery. Always unplug when no in use, remove battery if used on AC, after charged. Open the Control Panel, select Power Options, set to High Performance, select Change Plan settings, set Sleep to Never, select Change advanced power settings, scroll through the settings, set lid close and on/off to Shut Down. Configure other settings to your preference.
May 28, 2013 | Acer Computer Aspire V5-571-6869 15.6"...
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have a Dell XPS 1330 laptop and a DI-524 wireless router.
Unsure what your problem is exactly but here is something to try. Power off all computers, modem and router. Power up the modem first, and wait until it is completely up before proceeding. Next power up the router and wait until it is completely up, the only light that probably wont be lit is the LAN light. Then power up each computer, they can all be powered on at the same time, that part really doesnt matter. See if that fixes the problem.
Aug 11, 2009 | D-Link AirPlus DI-524 Wireless Router
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
My Maxtor Hd Wont show up anywhere in my laptop when i plug it in
it should still detect even though your using vista does your bios setting have usb2 enabled?? otherwise try a different usb port
Jun 17, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
Dell Inspiron 5160 won't charge.
wow, ive never seen a computer know what type of adapter is plugged into it... it definately sounds like a power system problem. three parts to this- the adapter, the battery, and the motherboard of the laptop, since that is what interprets and passes on the power from the batter/outlet to the rest of the parts of your computer. we're hoping it isnt the motherboard not recognizing your power subsystem...
but you took a good guess to replace the adapter. you want to make certain the old adapter-- the voltage etc that's written on it in plastic somewhere- that it matches exactly with your replacement adapter. (You just cant plug these thing into any computer it fits into, they have different requirements sometimes, even though theyre all laptops). If it does, then yes, I would assume it's the battery.
Try taking out the battery and running straight off the current, can you do it? Technically, you shouldnt need the battery, it will just act like a desktop computer.
You can get a reasonable aftermarket latop battery for 100-135 bucks, chinese. Compare it to what your manufacturer wants to charge you for a replacement.
BTW- youre out of warrantee, right?
Feb 02, 2009 | Acer Aspire 5100 Notebook
I need help with my acer orbicam 5610
http://www.theacerguy.com/category/orbicam/
Please try this site or go to the Acer site and download the drivers you need and for the orbicam. Just click on the driver to activate and your computer will do the rest.
Good Luck
Fehdi
Dec 19, 2008 | Computers & Internet
Toshiba Satellite A205-S4617 Notebook Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
