Question about Mitsubishi WD-62825 62" Rear Projection HDTV
We have a Mitsubishi DLP and the timer light is flashing on and off and I cannot turn the power on or off on the TV
  • Anonymous Dec 23, 2008
    I will never buy another Mitsubishi product again. This unnit was very expensive and didn't even last 3 years!!!
    Problem Solver:
  • 17 Answers
Bad signal board, DM module and or formatter board. Try replacing the signal board first. About 50% of my fixes with flashing timer LED was solved by signal board replacement. If this doesn't work, then try replacing the formatter board. And if still don't work, then DM module must be replaced.
Mitsubishi don't have a real answer behind these failures. I know and I've tried. Do have two of them just came in my possesion for repairs. One has same problem and just put in order for new signal module.
Posted on Jan 09, 2009
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
2004 mitsubishi DLP 62 "
the timer light part is misleading you Carlos, i think it is probably the internal power supply start up which is failing im afraid you will need a techie visit sorry,George.
Nov 03, 2010 | Televison & Video
The timer button is flashing and we can not use the TV I cant find my booklet on the TV
Install the Mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit form www.tvrepairworld.com the kit contains the capacitors and the CD with instructions. That kit will usually repair the blinking timer light symptom.
Oct 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Timer light is flashing and the set will not turn on
i need your confirmation that we can handle the repair we need to remove back cover and repair by parts.
Apr 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
