Question about Dell Dimension B110 PC Desktop
Dell dimensio B110 computer does not start beyond the startup window
  • 4 more comments
  • rpathman Nov 27, 2008
    thank you leecom72
    after I turn on the computer, I see the DELL start up screen with the white bar expanding. The shite bar does not expand completely. This screen also shows in the upper right f2 setup and f12 boot menu. I tried f2 and got to the BIOS setup menu. However I do not know what do do with this menu.
    If I do not press f2, the monitor goes blank, then very briefly shows a blue bar at the top with white letters in the center saying www.dell.com.
    any way I could phone you?
    Richard
    I tried hitting F8, but nothing happened.
    thanks
    richard
    I found the motherboard battery and cmos clear, but no cmos jumper (nothing like a green piece of plastic)
    thanks,
    richard
  • runningkranc Mar 05, 2009
    My mother in laws Dell Dimesnion B110 wont move beyond the blue screen with the white bar. It makse a noise like a fax machine and freezes up . I can choose the F8 and F2 menu but hitting any F key will take me to the regular windows and then the computer works just fine and the noise stops.I have tried to restore the system but it didnt make a difference.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    please describe in more detail
  • Eddy Schroeder Jul 08, 2013
    sounds like the hard drive is fried or is getting really weak
    New Friend:
Why is my dimension b110 keep loading in safe mode can't do anything?
Posted on Apr 03, 2013
  • Dell Master
  • 4,806 Answers
While the pc is booting up hit F8, it should take you to a sub menu, choose "last known good configuration" and hit enter, see what it does.
post back please
regards
Posted on Nov 27, 2008
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    ok the bios isn't loading properly, take the side panel off the pc and look for the motherboard battery, then look for cmos clear.
    as you will see in the photograph the cmos jumper is the green piece of plastic, move its position to the other position and press the on/off button, that will clear the cmos, put the jumper back in is original position and reboot the pc, you may get a message saying checksum error, just press F1 to continue , when you are in windows you will have to correct the time and date
    best of luck
    don't forget to rate us!!!
    regards
  • Lee Hodgson
    remove the battery and leave it out for an hour, make sure the mains power supply is removed from the back, place the battery back in after an hour and the cmos should be cleared
    regards
Dell b110 runs very slow
I highly suggest you buy a newer computer with windows 7...
But...
You need to delete any unnecessary files(like temporary internet files, cookies, cache, etc.)
To do so:
Download an application called "Ccleaner" and run the program and also you can disable many startup programs
Aug 01, 2012 | Dell Dimension 2400 PC Desktop
How do i completely take everything off my dimension b110 to take it back to when i first got it?
you have to insert your restore disk and reboot your computer, at startup your cd should start right away, click on restore to factory, and follow on screen instructions
Jun 09, 2010 | Dell Dimension B110 PC Desktop
I have a dell dimension b110 with Windows XP (i no longer have free tech advice from dell) I have tried evey soultion given to me by microsoft solutions and all the stuff it tells me in my own manual but...
Go to start, then run and type in msconfig then choose the startup tab from the box that appears. Everything that is ticked in here starts when you start windows xp that is why the pc is Sooooooooo slow, all you need running is your AntiVirus software if you have any! so untick everything except the AV software then click apply and then close, it will then ask to restart. Upon restart you will get a message about system configuration just tick box saying don't show this again and click OK. Everything should hopefully now be a whole lot quicker.
May 11, 2010 | Microsoft Windows XP Home Edition
Inspiron b110 wont turn on only green flashig
Unplug your computer, wait 30 minutes, plug it back in and try again.
If it still doesn't work, it's got a serious problem. If it isn't under warranty with DELL any longer, take it to a reputable repair facility.
Apr 14, 2010 | Dell Dimension™ B110 PC Desktop
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
How do I take a dell dimension B110 back to factory specs? Is it stored on the computer or do I need start up cd's?
You need the CD to assist and utilize any restore data that may or may not be on your hard drive.
Jan 04, 2010 | Dell Dimension B110 PC Desktop
How to open a dell b110 case
http://support.dell.com/support/edocs/systems/dim1100/en/SM/cvrop.htm#wp1076111
Lay your computer on its side with the computer cover facing up.
If your computer cover has a cover latch, slide and hold the cover latch.
Grip the indents on the computer cover, and slide the computer cover toward the back of the computer.
You can see how by folloing the link above!
And here is the manual if you need it
http://support.dell.com/support/edocs/systems/dimB110/index.htm
Good luck to you!
Please take a minute and vote
Nic
Jan 28, 2009 | Dell Dimension™ B110 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
After loading Window service pack 3 update, comes up blue screen
press f8 and go to safe mode and delete service pack 3. sp3 is known for problems
Sep 23, 2008 | Dell Dimension™ B110 PC Desktop
Dell Dimension B110 PC Desktop Logo
324 people viewed this question
Alun Cox
