Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Sky plasma tv psd4250 no picture
Hi there i have a sky pds4250 42" plasma, i can not get a picture at all only the sound what can i do or what part will i require many thanks
  • harris205 Nov 27, 2008
    hi there i have a sky pds4250 42" plasma, which i have had for over five years with about six fixes to the pcb now my warranty has run out sky is not interested this problem has just happen while viewing my favorite programme heroes i can not get a picture at all only the sound what can i do or what part will i require many thanks.dated 27/11/2008
It can be fixed by replacing the video processing chip. Sometimes together with some capacitors. But the problem is that the rework can not be done easily. It requires special equipment other than soldering iron. Refer ebay item claiming fixing the board. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250579462435&ssPageName=STRK:MESELX:IT
Posted on Mar 03, 2010
  • 135 Answers
Its the video pcb i have the same problem
Posted on Sep 21, 2009
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Hi i have a krf-v5030d and i am having trouble woking out how to connect it to my panasonic 37'' plasma th37px70b and my sky plus box can you help me please .thanks john
Hi John,
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
Hope this helps.
Regards, Mohammed
Oct 05, 2009 | Kenwood Audio Players & Recorders
42 inch DO42746 no picture or sound
It is still possible the z sustain board is bad. or an x driver board.
Jun 26, 2009 | Sanyo DP42746 42 in. Plasma Television
Plasma green ccreen with no picture but sound working
Check the scart output from the sky box. It could be on s-video or RGB. switch between the two.
Mar 16, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Vertical white lines on screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 10, 2017 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Just bought a samsung ps50a557s3f 50" plasma tv and the picture isnt very good.Have only got normal sky at the moment and i was wondering what the best settings are
Hi Smudger
Not sure if you still have this issue, but i have just bought this TV & also use sky (not + or HD)...
I got myself a Monster Cable Home Theatre surge protection unit from comet, basically it helps filter out all the background interference (picture & sound) & helps boost the signal sent to the TV..
I use a gold plated scart lead from the sky box to the TV & the picture is spot on.......i've not noticed any ghosting/pixeling etc & am well impressed...
The unit came with a top end HDMI cable & cost £135 (bit excessive you may think, but to buy the unit & cable seperate would cost £250!!) + the cable is a 'cable for life', so you can get a free updated cable as technology progresses :-)
My sky signal was always at half power (you can view this from the sky menu options) & now its almost full signal
Oct 06, 2008 | Samsung Televison & Video
LG 42 inch Plasma Picture in Picture with SKY satellite service
PIP only works off two seperate signals, eg you cannot watch 2 sky channels at a time, you can watch sky tv and then your analogue channel using PIP or freeview, you can then swap which is to be viewed as a large picture and which is to be viewed as the smaller picture or half and half.
Sep 07, 2008 | LG MZ-42PZ14 42 in. Plasma Television
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
