Question about HP Compaq Evo n610c Notebook
How do I reinstall space bar key on my desk top keyboard
I have removed the space bar key and can not get it back on. Can someone please help me or direct me to where I can go to get help. I just can figure it out.
  • kleinauclan Nov 27, 2008
    Thanks for the info it made me think about in a different way and got it fixed. THANKS for the help on the holiday. Happy Tanksgiving.
    Guru:
  • 257 Answers
Do u mean your spacebar key cutoff the keyboard if that is the case and the two edges used to pin it diwn is not there again then if you use a glue to glue it down it will work properly too ok.
Rate thius solution
Posted on Nov 27, 2008
Laptop space bar not working
you can just remove your laptop keyboard and replace it with new one from only opening some screw.
and if you want use temporary solution and use space bar temporary, then you can use " On-board Keyboard " for using all key which is on keyboard,
Please Mark this Answer as HELPFUL.
Mar 16, 2017 | Computers & Internet
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
I have a acer travel mate laptop , on the desk top the desk top bar which usually is on the bottom has now moved to the left side of the screen, how do i bring back to normal
click on start button in key board press alt space in displayed options select move press down arrow key to move your task bar to down
Sep 11, 2010 | Acer Computers & Internet
Reinstalled mozilla 3 times
open Mozilla Firefox and press ALT Key on key boar, now you can see all men bar appears on your Mozilla..Now right click any empty space near address bar of Mozilla Firefox and select option menu bar . now it will stay there forever.
See the pics below
Before
After
May 26, 2010 | Mozilla Firefox
How to reattach the space bar key on the SK-8110 Dell keyboard?
On dell's website there is a step by step instructions on how to attach it back on. I had to do the same thing on mine machine. Just go to dell's site and on the search bar on how to attach the keyboard.
Dec 10, 2009 | Dell SK8110 Keyboard
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
I have to press the space bar right in the middle for it to work.... any help?
Hi!
I had the same problem when i got the keyboard. In my case, it was because the tiny metal bar that is supposed to transfer the pressure from the right and left sides of the bar to the mittle was not attached correctly.
I removed all the screws from the back of the keyboard (note that there are screws underneath the rubber pads, but don't worry about them, they will stick to the keyboard again) and lifted off the top (including the keys). Then i could pop off the space bar from behind (didn't work for me otherwise... maybe it is possible to pop it off without removing all the screws) and correctly insert the metal bar into the mounting.
Hope this helps.
May 16, 2009 | Saitek Eclipse II
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
HOW DOES THE SPACE BAR CLIP GET REINSTALLED?
Take the wire piece out of the keyboard and attach it to the space bar by snapping the long horizontal section into the notched moldings you will see along one edge of the underside of the spacebar. Now turn the spacebar back over, orient it with the high side toward you and the lower side toward the other keys, fit the retainer ends into the slots in the keyboard, and push the spacebar center pin back into its hole. The wire is not really a retainer; it is there to transfer to the center pin any pressure applied to either end of the bar.
Mar 07, 2009 | Logitech 967437-0403 Keyboard
HP Compaq Evo n610c Notebook Logo
244 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
