Question about Digital Audio (DADVDP) DVD Player with AM/ FM/ RDS/ 5.1Ch/ 4 x 40 Amp Car Video Player
Sony AVD-S50ES fully dead.
Sony AVD-S50ES problems.
Only indication of life is "standby" light when powered up.
Power supply board out.
No display, no fan. All low voltage outputs greatly reduced or missing.
Help
  • winemaker670 Nov 27, 2008
    I have service manual, need experienced advice on loss of all low voltage power.
  • 10,594 Answers
Below is view of voltage out put connectors of power supply of AVD-S50ES
You can confirm volts on connectors as mentioned here.
Sony AVD-S50ES fully dead. - 6a9021f.jpgGood Luck.
Posted on Nov 27, 2008
Sony AVD-S50ES DVD Player Had this in storage. Decided to sell. Verified it played CD's and DVD's video and audio were being sent out appropriately. Track info displayed on front panel. Buyer claims...
Be careful that it isn't a scam.
Some people will claim non-functionality hoping to get a refund without having to return the perfectly working unit.
It's possible it was damaged in shipping, but unlikely if it was packed well.
If they are demanding a refund, tell them that your policy is like any other - they need to return the unit, and once you have verified that the unit is indeed defective, you will issue a refund.
Mar 22, 2011 | Sony AVD-S50ES DVD Player
Sony TV KDF-E42A10 Projection TV Standby light flashes 4 times. TV turns on for 5 seconds and turns off with standby light flashing 4 times. TV will not stay on.
Your power supply board is not yet dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout in solving the problem......
Jan 11, 2011 | Sony KDF-E42A10 42 in. LCD Television
When attempt to turn TV on, either by remote or power button, the standby indicator light begins to flash and TV fails to turn on. After several times of clicking the remote, the TV turns on. What could...
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this help in solving the problem....
Dec 24, 2010 | Sony KP-53HS10 TV
I have the Bravia 40" KDL 40V3000. When I turn the TV on the panel powers up then the TV goes to standby and I get 13 flashes from the standby light. Reading on one of your other posts, I went ahead and...
Power supply board is dead 90% of the times.When the power turn on LED power light indication flashes.5% might be the Tuner board,that the board taking in the incomming broscasting cable plug into this board.5% might have both death boards,power supply board and the Tuner board.Problems,u have never indication LCD inverter board,backlight problems.U shouldn't have replaced the LCD inverter backlight board,bacause backlight are dead,have flashes of picture few sec.than dies,still have hear sound.
Aug 05, 2010 | Sony BRAVIA KDL-40V3000 Television
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony 57" projection standby light flashes fast 3 times wont turn on eventually will turn on after several tries
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again. But if otherwise,
Jun 25, 2010 | Sony KP-57WS500 57" Rear Projection...
Will not turn on
Power supply board have dead leakage gases componnents call capacitors.These capacitors are dead or will not work properly.These capacitors alway bulges up it top or puff up it top.U know basic electronic's and soldering?Take ur tv aparts.Go all around the power supply board searches for these bulges or puff it top capacitors.Replaced these leakage gases capacitors,ur power will return to normal functions,and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 03, 2010 | Sony BRAVIA KDL-40V3000 Television
My KP-65xbr10w appears dead no life when plugged in.
If you have no indication of power you may have lost all of the voltages to your power supply, including the 5 VDC standby voltage. I am not sure if you can get a new G board, but you should be able to get the individual components that you need. I would look for the cause of the power supply failure first, and I think I would look at your Horzontal Output Transistor. I am thinking it is Q501, Q401 or something like that. I have repaired many of these and the HOT is most likely the problem. A shorted HOT would cause the power supply fusables to blow and the entire set would appear to be dead.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Sony KP-65XBR10W 65" Rear Projection...
Car Audio & Video Logo
210 people viewed this question
Top Digital Audio Car Audio & Video Experts
Joe Ankney
Level 1 Expert
Tom Chichester
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
