Question about Frigidaire GLER341A Electric Dryer
Frigidaire Dryer takes too long to dry.
I have a Frigidaire electric dryer GLER341A and it takes too long to dry. The vent system is fine and just to be sure I removed the hose from the vent and ran it with the same results. I found the 4.4k ohm power resistor falling apart on the back of the timer knob and it was barely even attached and all broken. I replaced it and the dryer seems to work a little better but still takes too long to dry. Do you think my heating element is partially bad. The dryer used to dry the clothes on MEDIUM and would burn them on HIGH when we firts bought it. Then over time it wouldn't dry on MEDIUM, only on HIGH. Now they do not dry all the way on high even after replacing the resistor. My next step would be the heating element or thermostats. Do you know the correct resistance readings for the parts.
  • 1 more comment
  • John Perin Jan 13, 2007
    The thermal limiter reads good. The control thermostat reads good across the thermostat switch but reads high across the resitor in the thermostat. There is a 28k ohm resistor in the thermostat and it reads 40k ohm. The high limit thermostat reads good. I disconnected the wires off the timer and fabric select switch and measured down the wires to read the heater and it read about 1.6 ohm. These measurements are not 100% accurate because I used a cheap analog meter. Though they are accurate enough to know something isn't right. Also that 4.4k ohm resistor I replaced that was bad went bad again after running the dryer through a few cycles. and I noticed a few burn marks on the teminal on the resistor.
    Any help deciphering this info would be great.
  • Anonymous Nov 09, 2007
    My dryer has been a piece of crap from day one... It over heats to the point of almost burning.... Shrinks clothes like they`re for a baby, shuts off all of the time w/o properly drying the clothes... I hate my frigidaire dryer... I`m afraid it`s gonna burn the house down...and it`s frustrating when you have wet laundry to dry and the loads are stacking up because it does not work properly...
  • ck_face_21 Oct 20, 2008
    my frigidaire gler341AS2 turns on fine but after we moved the dryer wont heat up the thing blowing out air but not heating up and drying the clothes at all i think the heating element may be bad not sure where it is or how to get at it ! How do i know if it is the heating element and not something else?
    Novelist:
  • 159 Answers
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Posted on Jul 13, 2007
SOURCE:
Dryer squeeks very loud. Still drys but noice is very schrill.
Good Morning Friend,
I understand that your Frigidaire dryer, model# GLER341A, is drying, but is making a very shrill and loud squeaking sound. There could be several possibilities that might be causing this sound. Please make sure your dryer is level. Check from side to side, front to back, and corner to corner. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire GLER341A Electric Dryer
My frigidaire dryer model number gler341as2 is giving me a burning smell why is that?
Hi kmcgilvery...
That burning smell is probably a lint build up in the blower system of the dryer.
You will need to remove the back of the dryer and look for the vent tubing going to the hose connected to the outside. Once you find the tubing then disassemble and clean the tubing and blower wheel of dust...then clean your flexible vent tubing you have attached to the back of the dryer.
Please take time to rate me
Sep 05, 2011 | Frigidaire GLER341A Electric Dryer
My dryer takes a long time to dry, what could this be?
Normally when a dryer is getting hot but taking too long to dry it indicates that it either has a clogged vent or poor air flow. You can check this by turning the dryer on and then going to where it vents out of the house and see if there is a strong air flow, or by taking the vent off the back of the dryer and letting it run and see if the clothes dry in one cycle. 99% of the time its going to be some sort air flow problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 09, 2010 | Frigidaire GLER341A Electric Dryer
My dryer is taking about 4-5 hours to dry one load. is the heating element bad? how do you change them?
it sounds like the vent tube is restricted, disconnect and clean, but here is a website to help you if you want to change the element, Good Luck Tim
http://www.partselect.com/dryer+replace-heating-element+repair.htm
Oct 24, 2010 | Frigidaire GLER341A Electric Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
My model # gler341cco electric dryer is making a
The only way to know for sure what is going on is to inspect the innards. I have assembled some photos to assist you: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2010 | Frigidaire GLER341A Electric Dryer
Dryer heats but only at low temperature. takes several cycles to get cloth dry
Usually the relay (in the internal thermostat) is bad or if their is a second heating element, it can be bad. Also, the controller/timer can cause the problem but usually not.
Good Luck!
Oct 07, 2009 | Frigidaire GLER341A Electric Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
Moisture in dryer
you have a clogged vent, somehow your vent has become clogged either with in the hose, or where it exits the house, the moisture being removed from the wet clothes is not leaving the unit. CHECK YOUR VENTING POTENTIAL FIRE HAZARD!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
865 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
