Question about Sharp R-1480 Microwave Oven
Plate does not rotate freely and make noice
The plate of my 6 years old JVM1650 does not rotate freely and making noice. Do I need clean the belt and how? Thanks a lot!
Carl My Sharp Carosol Microwave plate inside is not rotating and it makes weird sound. But it is still able to heat the food.
  • Sharp Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 27, 2008
Microwave makes grinding noise when microwave plate on turntable
check for the roller spider under the plate
small plastic item that has 3 (4) rollers that allows the plate to turn freely
May 25, 2015 | Microwave Ovens
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
Lg micowave model ms-2645dpa turntable stops and then goes some of the time.
sounds like the drivr belt is worn or sliping, is the plate turning freely on the runners if there worn they can cause the plate to drag that can also cause the this problem
Aug 12, 2011 | Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
PLMVZ169HCA Turntable slips on the glass plate
hmmm? me's thinking about this one!!!!
the glass plate has drive dogs on the bottom of it, that fit into drive dogs on the turn table, if its not meshed up right it just spins freely and normaly throw's the glass plat off??? are the bearing that are under the glass plate turning freely? thats the big ring that the plate rides on near the out side edge of the plate, and can be taken out for cleaning??? it looks like a hoop with 3 or 4 rollers in it??? if you forgot to put this bit back in the right way up after cleaning it thats the problem???
Oct 23, 2009 | Frigidaire PLMV169DC Microwave Oven
The inside tray jumps up and down side to side it is not following the track/groove
MAKE SURE IT IS CLEAN UNDER THERE AND THAT THE HOLDER WHEELS ROTATE FREELY
Apr 27, 2009 | Microwave Ovens
There is no belt in your model - the turntable is motor driven. The problem is either the motor itself or the coupling that engages the glass tray.
The motor (GE part # WB26X10038) is a very common failure as the internal gears are plastic and tend to strip.
You can view the motor at this link...
www.microwaveglasstrays.com
Jul 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Jan 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Sharp R-1480 Microwave Oven Logo
690 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
