Question about LG LHT734 System
Audio delay from Aux inputs
I just bought the LG lht734 from radioshack.
I own a Numark PT01 Turntable (with built-in pre-amp) that I have tried to run through the RCA aux inputs on the back of the unit and through the "audio in" aux input 1/8" jack in the front of the unit. No matter where I plug the record player in, there is a delay in the audio (the sound coming through the speakers is almost 1 whole second behind the sound coming off of the record). This is very annoying because I can hear loud noises (like cymbal crashes) coming from the record before it comes through the speakers.
I exchanged the first unit for another, thinking it was defective. However, my new unit does the same thing!
I also have tried to plug other things into it, such as my laptop computer and mp3 players. The sound delays in these instances as well.
No one has been able to explain what is going on....is it just a problem with the LG lht734 that I have to live with?? Any help would be appreciated. Thanks.
  • 6 Answers
SOURCE: mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Posted on Nov 04, 2007
Cerfer39
  • 709 Answers
SOURCE: how do I activate AUX input?
Hi Greg212,
Got your procedure out of the manual. Look below. Hope this helps you.
Posted on Nov 28, 2007
  • 375 Answers
SOURCE: Programming AUX as a channel.
pick up a universal remote
Posted on Mar 28, 2008
SOURCE: hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Posted on Apr 19, 2008
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Pioneer VSX-D810X
Depends on the turntable. Your turntable would need to have a built-in preamp in order to work.
Apr 23, 2013 | Audio Players & Recorders
I cannot get the audio from my electro brand turntable (L2650) to work thru my Sony DVD Home Theatre System DAV-DZ170.
would you please try to explain how did you connect it to each other ?
and which input you have used on DAV-DZ170 ?
does your DAV-DZ170 have any "PHONO" input ?
it is important to know the existing connection to offer acceptable solution..
Thanks.
Jun 22, 2011 | Audio Players & Recorders
I have a Numark TT 1610 and it has the old school red and black audio out put wires, and just playing some of my old records is what i wanted, but its sound comes through my speakers so soft i have to...
It looks like your amplifier has not got a "magnetic cartridge pre-amp" built in, or you have it connected to a tape/cd input instead of a phono input. All you need is to search online for one and that will connect between your deck and amp and it will then be the same volume as anything else connected to the amp.
Jun 17, 2011 | Numark TT1610 Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
I just bought a pioneer pl-200 turntable at a flea market. I plugged it into an old am/fm/8-track amp's phono input and I know the amp cranks on fm but on phono, it's very low sound. It does get louder...
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
Sep 21, 2009 | Audio Players & Recorders
EZ audio converter hangs
not compatible with itunes 9 no solutiuon complain to numark turntables
Sep 16, 2009 | Numark PT01 Turntable
Hooking up Turntable to Yahama HTR-5660
you have to have a pre amp, or an old reciever with a phono input.
you dont have to use the aux input, the cd or md-cdr inputs will be fine, but you do need that preamp for that reciever
Nov 29, 2008 | Yamaha Audio Players & Recorders
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
LG LHT734 System Logo
136 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
