Question about Dell 1700n Laser Printer
Repair on Dell 1700n
I need to find schematics and/or repair manual for this Dell Printer. I am having to replace the input roller clutch & lever assembly and feed rollers and I am not sure how.
  • Anonymous Nov 29, 2007
    I also need a manual/schematic for making repairs on rollers, etc. Thank you.
    rsande@sbcglobal.net
  • RAS1 Nov 29, 2007
    I also need a repair manual/schematics for the Dell 1700/1700n. I need to replace rollers. Thank you for your help.
  • 28 Answers
Hope this helps
Posted on Feb 12, 2010
I have a Dell Laser Print 1700n and it's not picking up paper. I've cleaned the rollers - I even turned them inside out and that worked for a while. If I'm lucky it will pick up a sheet or two and then it...
It sounds like you may need a new roller kit. The rollers just wear down over time and need to be replaced; like you saw when you turned them inside out. They are not too expensive and are usually very easy to replace. I have used fastprinters.com before to order mine. You should be able to find two rollers for your paper tray for around $15 and a transfer roller for under $30.
The part number for the Tray 1 Pickup Rollers is 56P1820. It is a Lexmark number by the way (they are the same company).
The part number for the Transfer Roller is K4437 or JT891.
I would recommend replacing the rollers that you turned inside out (Pickup Rollers) first.
I hope this helps! Good luck!
56P1820
56P1820
Mar 02, 2011 | Dell 1700n Laser Printer
My Dell 1700 prints half the sheet, then stops
I have the same problem. Open the back cover of the printer and in the centre of the rollers to feed the paper out there is a paper sensor (a lever assembly attached to a switch) that lets the printer know when the paper has 'arrived' at that point in the printing process and also when it 'leaves' that part of the printer. On my printer the top of the lever has somehow snapped off so the lever/switch isn't being activated when the paper arrives at that point and the printer assumes there is a jam somewhere. I have removed the lever and glued a small piece of plastic to it to replace the piece that's broken off. It's a fiddly repair and I've had to re-do it a couple of times. I need to find a replacement assembly but part seem to be hard to come by and I don't know the part number to do an internet search.
Jun 23, 2009 | Dell 1700n Laser Printer
Rollers squeak.
This probably means the rollers are getting slick and a little glazed. Dell printers seem prone to this. It's harmless unless it is the primary (big) rollers that push the paper up into the toner drum. See my advice to the paper jam question for fixing that.
Jun 18, 2009 | Dell 1700n Laser Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Paper won't pull from the paper bin
ROLLER MAYBE HAVE OIL FROM HUMANS OR OTHER TYPE OF PAPER PRODUCTS,
TRY A DIFFERENT TYPE OF PAPER
MAKE SURE THE PAPER TRAY IS IN PROPERLY,
PAPER HAS MAXIMUM #'S OF SHEETS OF PAPER,
COPIER NEEDS TO BE SERVICED AND ADJUSTMENTS NEED TO BE MADE ON THE PICKUP TRAY, SERVICE TECHN WILL KNOW WHAT TO DO TO FIX THE ISSUES TO THE MACHINE.
ROD
Feb 05, 2009 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Dell 1700 Transfer Roller
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Jan 06, 2008 | Dell 1700n Laser Printer
Dell 1700n Jamming
try "rotating the pick up tires". (dell tech's phrase, not mine). pull the paper tray clear out of cabinet and look up inside the bottom of the printer. you will see a t shaped assembly with 2 large rubber tires (rollers). pull the assembly down (spring loaded) and peel the tires off the plastic mounting rollers. turn the tires inside out and replace them.
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
331 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
