SOURCE: I have a Saab 9-3 TDi 2001. The engine warning
Hi
If your engine warning light has come on this is indicating there in a serious problem and the limp mode has been switched on to safe guard the engine. It could be a number things, but I'll give you some basic things to look at which may help you.
If all these are ok then check these areas:
If all these are ok then there is a problem regarding sensor faults, fuel pump timing, and further in depth diagnosis will be needed. Hope this is helpful, let me know how you get on.
Jason
SOURCE: abs and traction lights stay on saab 9 3 2005 1.9
The abs light , when on turns off the traction control thats why that light is on,once the abs is repaired the traction light will go out, you need to first have the computer scanned for codes, the codes for the abs are stored in the abs computer, these codes will tell you what part of the system is not working. most of the time its a wheel speed sensor but scanning the codes is needed to find out,
