Question about Microwave Ovens
I have a panasonic v681 convection microwave when the microwave turned on for whatever time it starts for approx 2 seconds then switches off for no apparent reason
  • Microwave Ovens Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 27, 2008
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
In Canada, you can find an authorized Panasonic servicer here.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
This mircowave shuts off after 59 seconds all of the time ????
Change the Damper Motor and switch. Cost is approx $30.00 and you must remove the microwave from the mounting bracket and remove the cover to gain access to the motor and switch.
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Panasonic dimension4 microwave
check the damper motor is opening and closeing
Jan 17, 2010 | Panasonic NN-T888S Convection/Microwave...
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
The microwave works for only 8-9 seconds, then stops
It may be in demo mode.  On some units if you hit the timer/clock button 4 times to turn demo off.
Feb 02, 2009 | Panasonic NN-C994S Convection/Microwave...
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
Mar 11, 2007 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
