Question about Canon PIXMA MP160 All-In-One InkJet Printer
Can i get a diagram how to install my new ink #40 and #41 in
  • 2,153 Answers
Go to this link. In the search window in the center of the screen, type "install ink" and click on the Search button. Select the option "How do I install ink cartridge(s)" and you will get an illustrated, step by step guide.
Posted on Nov 28, 2008
SOURCE: ink cartridge installed wrong
Brought another printer.
Posted on Jul 07, 2008
vegakitten20
  • 685 Answers
SOURCE: installed new ink & it says "Print head is not installed" -
try to unplug it and plug it back in
Posted on Mar 04, 2009
  • 355 Answers
SOURCE: ip1300 does not recoganise the inks
cleane the bouth the cartridge head then try other wise change the cartridge
Posted on Oct 03, 2009
  • 183 Answers
SOURCE: installed new ink cartridges mx
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Posted on Feb 19, 2011
sunandjoon
  • 125 Answers
SOURCE: every time i turn my
r u sure new cartridge is not refilled one?
E5 error means cartridges are not readable.
When you refill your canon cartridge, especially for color one, it happens. (after 4~5 times of refills)
So you have to replace the cartridge with brand new one.
(for your additional reference, it doesn't happen to black cartridge)
So at least you can refill black...
If you would like to save money, try nozzle injection refill kit by ROADINK.
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.">
Posted on Apr 26, 2011
Need a wiring diagram for a Swann security camera model 642 3960 it has 9 wires what I cook the wire where the wires go do the wiring diagram
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover
Mar 06, 2015 | SWANN Home Security
My printer is blinking E5.
hi...e5 = you printer cannot detect your cartridge...try to clean the cartridge chipset using a clean tissu....or make sure you using a cartdrige no 40,41.....but the best solution is change the new cartdrige....
Apr 17, 2010 | Canon PIXMA MP160 All-In-One Printer
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
MFC 5440cnz I get ''unable to clcean message'' have unplugged it and restarted cimouter, but still getting message
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 10, 2009 | Office Equipment & Supplies
Unable to clean
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Nov 05, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
Nov 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Error message one brother mfc-5440cn
Oct 28, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to print see troubleshooting and routine maintainance in users guide Have read through guide, followed all instructions,cleaned, replaced cartridges , turned off at main supply AND still same...
Oct 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to clean,check manual
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
We have a new Canon MP190 printer. Cannot figure
1. Go to the following link: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP190"
5. Click "GO"
6. Under "Please enter your question:", enter the following text: "How do I install the ink cartridge(s)?"
7. Click "Search"
8. From the search results, select the first selection. You will get a page with diagrams illustrating how to install the ink cartridges.
May 15, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
54 people viewed this question
old marine
old marine
