Question about Pioneer VSX-D914 Receiver
AV Receiver pioneer vsx D914 does not turn on
When I plug the receiver to the wall it will just blink once several lights (dvd, tuner, tv sat, dvr, cd) but does not turn it on.
I appreciate your help. Also if you know how to do the master reset could maybe help.
Thanks a lot,
Luciano
  • Anonymous Mar 15, 2014
    I have a vsx-90txv receiver and i cannot get it out of the MCACC mode. I have tried puching return buttom by system set up, unplugging and plugging back in (once plugged back in MCACC light continues to blink ), going into tuner , tv, dvd modes but it will not. TV does not reconize HDMI cable when running from receiver toTV. When HDMI cable is ran from cavble box to TV it is recognised. How do I get out of MCACC mode?
See now what happen to me just last night actually was I was listening to music and had the receiver turned up to about -55. all of a sudden, it showed me AMP ERROR and shut off all on it's own and would not turn on.... I later was snooping around my wiring and fount two wires were touching. I have had the receiver unplugged since the incedent last night and I am going to try to get it working when I get home from work.. I know that it is a beautiful sound system and its sound quality is just amazing. It's definately the best system I have owned and I really hope that leaving it off for 24 hours will reset it and make it work again. I don't really have the money to go out and buy a new one.. nor do I really want to... If you have any luck you can let me know! Thanks!
Posted on Oct 13, 2009
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
My power went out while watching TV. Now there is no sound when I turn my receiver to TV/SAT. If I put the receiver on CD there is sound but no picture. The receiver works fine if I go to DVD; there is...
It would seem the TV/SAT source is where the problem lies. No picture with CD? Really?
How about bypassing the receiver to prove what is failing?
Apr 21, 2011 | Pioneer VSX-35TX Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
No sound when using 6 channel analog inputs
2 potential issues, first make sure the dvd player audio menu setup is set correct for 5.1 outputs, not DTS or Dolby Digital bitstream, can be difficult but read the user manual under sound options if possible, second be sure the receiver is set to act as the "amplifier only setting " i.e. DVD 6 channel input, maybe EXT IN , not sure what pioneers mode is, but all you need to follow is the dvd player is outputing 6 channel signal paths, and the receiver is acting as six amps, unless of couse you are using a subwoofer line out.
Jan 25, 2009 | Pioneer VSX-D914 Receiver
Cannot fix the sound
Take it back this receiver is out dated by at least 5 years (mine is over 5 years old) Purchase a newer one......
Jan 17, 2009 | Pioneer VSX-D412 Receiver
Av illiterate
Make sure your cables are all properly connected
Jan 28, 2008 | Pioneer VSX-455 Receiver
DVD video stops; audio continues
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Dec 10, 2007 | Pioneer VSX-D914 Receiver
Pioneer VSX-D914 Receiver Logo
174 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
