Question about Kitchen Ranges
Diplomat gas hob, minimum burner setting on all burners to high causing food to burn. Can you adjust flame?
  • Anonymous Jan 14, 2009
    Same proble here, there must be adjustmant but I can't find it. I'll keep looking
  • teflo Mar 07, 2009
    All the burners on my Diplomat LPG gas hob are too fierce.How and where can I adjust the gas pressure?(Model ADP1140)
Buffalo12980
  • 625 Answers
SOURCE: burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Posted on Aug 30, 2007
bigg t
  • 640 Answers
SOURCE: burners with yellow tipped flames
are you using propane or natural gas?if propane you need to clean the burner real good.propane burns very dirty and the soot clogs the burner.if natural gas is used look on the end of the burner,youll see an air shutter all you do is turn the shutter to increase or decrease the air flow.
Posted on Jan 06, 2008
  • 1073 Answers
SOURCE: Propane gas flame too high
if it set up for propane or natural gas need to make sure if for propane you need to change the orifice in the cook top, it is shipped for natural gas call the store and they can order the kit
Posted on May 06, 2008
SOURCE: Flame burns too high t0 simmer
Check youe installation manual, or downlowd one from the Amana website. Page 9, Low Flame Adjustment (for propane) or page 10, Reset the Valves for Natural Gas, explain how to adjust the flame height. It is easy, just be certain not to get carried away with how hard you crank on the screws: all hold small pieces in place or are for adjustment, not holding major structure together.
Posted on Jan 28, 2009
Maytag317
  • 1136 Answers
SOURCE: flame to high
Hi, To lower the size of the flame, turn the orfice on top of the gas valve in the oven. You will need a 1/2" wrench and need to turn the orfice clockwise to lower the flame.
please let me know if this helps or if I can assist you further.
Vic
Posted on Jul 04, 2009
Flame on main hob of range master 110 is yellow and smelly also black sooty deposit left on jets
Ream out all the orifices and air venturi holes on the burner, adjust the air-ahutter, the air-shutter is usually nearer the valve/knob than to the burner. Yellow flame is an imbalance of fuel to oxygen and is creating Carbon Monoxide and not burning cleanly... this is the same problem that can make a furnace deadly. Blue flame=neutral flame.
Apr 25, 2016 | Rangemaster 110 (Gas) Kitchen Range
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Oven flame too high
This is cars and trucks but i will endevour to give some sort of answer ,the flame being to high could be caused by a faulty regulator if used from a gas bottle or again the regulator on the gas meter if mains gas ,alternativly the jet that feed the burner has a enlarged hole in the part that you can see with the flames ,well at the bottom of that a jet that injects the gas into the burner which also has air holes in the bottom to mix the gas so look at the burner first and see what you can see in the way of any air holes being blocked with dried fat
Mar 19, 2012 | Cars & Trucks
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Minimum distance between diplomat chimney extractor and gas hob
Minimum above a gas burner should be 750mm and for electric hob should be 650mm.
Aug 07, 2009 | Kitchen Ranges
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Kitchen Ranges Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
