Question about Watches
Luminox camera what setting would you put luminox on for low lighting tdv310 camera
  • Anonymous Apr 09, 2009
    I have a luminox LX908.
    The video playback on the camera has no sound. Is there a speaker as there is a microphoe to pick up sound.
    The sound is ok on th computer dowmload
I HAVE A LUMINOX 3100 I THINK IT LOOSES TIME IS THIS A SIMPLE FIX?
If any battery operated watch starts losing time or displaying the incorrect time, this is usually indicative of a battery going bad and needing replacement. My Luminox 3100 started lagging in time and I noticed that the second hand would intermittently stop. I also have a Suunto Vector (Digital) wrist-top computer and the times along with the compass, altimeter, light and alarms all started to act crazy and all it happened to be was the battery being run down. Coincidentally the Suunto has a battery gage that only appears and flashes during low battery charge.
BL: Try the simplest thing first, change your battery. Please be very careful not to break the O-ring on any watch that's waterproof/resistant as this will render the protection useless. Also if your watch is still under a manufacturer or vendor's additional warranty, get them to change it as not to void your warranty. 'Hope this helps!
Dec 04, 2010 | Navy Seal Luminox Dive Watch
How do you set the alarm for an Luminox Field Chronograph 1887?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all LUMINOX watch manuals. Rate me, please.
Mar 04, 2010 | Luminox Watches
How do i change the time on my luminox watch and is it normal for my watch for the second hand to move every five seconds
That is an EOL (end of life) feature, its your watches way of telling you that the cell has become very low and needs replacement. Good luck :)
Nov 28, 2009 | Navy Seal Luminox Dive Watch
The crown on my Luminox 8362 doesn't push and pull to set the watch? HELP!!! THANKS!!!
If it's like my Luminox 1828, the crown has to be unscrewed before it can be pulled out and worked like a regular crown. Just don't forget to screw it back down afterwards.
Oct 18, 2009 | Luminox Watches
My problem is not mechanical. Rather, an issue of authenticity. I see a lot of information regarding replica LUMINOX watches. My question is: How can a potential buyer detect a "fake" from the real-deal?
Well I'm, not an expert of fake Luminox, only the real ones, but I will tell you that a 'real' Luminox will be heavy to the touch, good quality steel...another thing that is a must if it is real is the glass tubes on the hands and on the dial at the hour markers...they are very small glass tubes that are not 'charged' by putting in light, they stay lit regardless of any surrounding factors...most fake watches will have 'painted' on glow onto the dial and especially the hands...this model also has a screw-down crown and sapphire crystal...hope this has helped...good luck :)
Jun 07, 2009 | Luminox Marine 1590 Wrist Watch
My Luminox (one of the original navy seals model)is losing time. Can I adjust it, and how?
there's really no way to adjust this problem...unless the watch has been severly jarred or damaged in some way it is most likely just a low or dead battery..if it has been damaged only a watchmaker would be able to replace the faulty gears or parts
May 31, 2009 | Luminox 3007 Original Navy Seal Diver...
The second hand on my Luminox 3007 now moves in 4 sec increments
thaqt is an EOL problem...basically telling you the cell is very low
Apr 16, 2009 | Luminox 3007 Original Navy Seal Diver...
Setting alarm for Luminox 1848 Field Alarm Chrono
Normal 0 Here is the watch movement manufactures instruction .pdf.
RONDA startech Cal. 5130.D
http://www.ronda.ch/pdf/ba5130.De.pdf
Feb 17, 2009 | Luminox Silver Series 42mm Watch - Black...
Watches Logo
63 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
