Question about Cameras
Canon Powershot SX100 Change battery light comes on when I install new batteries. I have cleaned terminals, installed in correct orientation, and used AA Alkaline batteries.
    Genius:
  • 1,011 Answers
Dear sir/madam,
it only fixed to put rechargables in. tried to use rechargeable batteries.
Alkaline batteries stored at "room temperature" self discharge at a rate of less than two percent per year. So normally refrigerating or freezing them will only help maintain their charge by a tiny amount. Hardly worth the effort of chilling them. However, if alkaline batteries are stored at higher temperatures they will start to lose capacity much quicker. At 85 degrees F they only lose about 5% per year, but at 100 degrees they lose 25% per year. So if you live in a very hot climate or are storing your batteries in a very hot location, it may be worthwhile for you to store your alkaline batteries in a refrigerator instead.
NiMH and NiCd batteries self discharge at a MUCH faster rate than alkaline batteries. In fact, at "room temperature" (about 70 degrees F) NiMH and NiCD batteries will self discharge a few percent PER DAY. Storing them at lower temperatures will slow their self discharge rate dramatically. NiMH batteries stored at freezing will retain over 90% of their charge for full month. So it might make sense to store them in a freezer. If you do, it's best to bring them back to room temperature before using them. Even if you don't freeze your NiMH batteries after charging them, you should store them in a cool place to minimize their self discharge.
When u use cheaper batteries usually get that message, but when u use more expensive batteries It don't and can take 400+ pictures.
For an example when u use Rayovac Heavy Duty batteries (4 pack costs about .99) It can take maybe 20 pictures, but when u use Energizer batteries ($3-$4 for a 4 pack) 400+ pictures can be taken. I'm not sure why this is, but it is something.....
thanks
good luck
Posted on Nov 27, 2008
  • 146 Answers
Make sure camera is off and not on when you change battery's. It probably messed with something with you just took the batterys out while it was on. So turn Camera off take new ones out put old ones in turn camera on, turn camera off take old ones out and put new ones in and start it up.. Hope it helps.
  • Patrick Shaffer
    Patrick Shaffer Nov 28, 2008
    LOL the dude with the post above is totally bullshitting you,
  • Cameras Master
  • 4,806 Answers
Does the camera still work ok?
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    if all checks out with the camera and the pictures/video are unaffected then i don't think you have anything to worry about, if there is anything else the camera is doing that it shouldn't be doing please let us know
    regards
  • Lee Hodgson
    some LED light appear to be on all of the time, and there is nothing wrong with the device
    regards again
How do I install a new battery? The manual doesn' t cover this.
Many garden tractors have the battery located under the seat. Move the tractor to an area you can work easily in and shut off the ignition.
1 Access the battery / compartment.
2 Identify the (-) Negative and (+) terminals on the battery.
3 Note orientation of the battery (-) or (+) as it is installed in the tractor.
4 Place a piece of tape on the (-) battery cable's insulation and another near the (-) battery terminal.
5 Photograph the battery with cell phone, etc.
6 Remove any clamps or brackets if they will be in the way of removing cables.
7 Remove the (-) cable from the battery terminal first by loosening the bolt or screw with required wrench, battery pliers, screwdriver, etc. by lifting it up / sliding out of the terminal.
8 Remove the (+) cable from the battery terminal last by loosening the bolt or screw with required wrench, battery pliers, screwdriver, etc. by lifting it up / sliding out of the terminal.
9 Remove any clamps or brackets if not already done previously.
10 Lift the battery out of the compartment straight up without tilting to prevent spilling acid from the battery.
11 If acid is not already in new battery: place new battery on several layers thick of newspaper and
a add battery acid to new battery as per instructions included with the battery.
b Place caps on battery when filled.
12 Identify the (-) Negative and (+) terminals on the new battery.
13 Place a piece of tape near the new battery's (-) terminal.
Place battery into compartment so that it is in the same relative orientation as step #3 above. This will ensure both cables will reach the correct terminal on the battery.
13 Check installed battery to photo to be sure it is oriented correctly.
14 Install any clamps or brackets if they will not be in the way of installing cables.
15 Connect the (+) cable [no tape] to the (+) battery terminal [no tape].
16 Double check that the (+) connection is correct and tight.
17 Connect the (-) cable [with tape] to the (-) battery terminal [with tape].
18 Double check that the (+) connection is correct and tight.
19 Install any clamps or brackets if not previously done in step #14 above.
20 Dispose of newspaper, acid container, etc in trash.
21 Recycle old battery where new battery was purchased / collect deposit.
Done!
May 19, 2015 | Garden
Canon Powershot A3400 won't turn on
Hi Jessie,
I looked at the troubleshooting section of the Canon Powershot A3400 Is manual and it suggested the following:
  • Confirm that your are using the correct type of battery, and that there is sufficient charge (p. 163). Sounds like you did this.
  • Confirm that the battery is inserted facing the correct way (p.17)
  • Confirm that the memory card/battery cover is fully closed (p.18)
  • Dirty battery terminals reduce battery performance. Try cleaning the terminals with a cotton swab and reinserting the battery a few times.
The manual also said that the batteries can deplete quickly in low temperatures. "Try warming the batteries a little by putting them in your pocket, for example, ensuring that the terminals do not touch any metal objects."
You can find the manual online here: http://aggregate.org/CACS/psa4000is-a3400is-a2400is-a2300-a1300-a810-cug-c-en.pdf
I also uploaded the manual to FixYa's Canon Powershot A3400 Is Product Page:http://www.fixya.com/support/p2861926-canon_powershot_a3400_16_megapixel_16_mp
Lastly, you can also check out Canon's Service & Support page for the camera: http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a3400_is#ServiceAndSupport
Best of luck!
Dec 20, 2013 | Canon Powershot A3400 Is 16 Megapixel...
I put new batteries in and I can take 1 picture then the screen goes black and it says change the batteries. What's the problem
I would try cleaning the battery terminals with a swap and a bit of rubbing alcohol.
See if that helps. Just a suggestion. Maybe the battery terminals are dirty.
Oct 30, 2011 | Canon PowerShot SX100 IS Digital Camera
I got problem with my Canon powershot sx100 IS camera. It is giving only 4-15 pics with new alkaline batteries after that LCD screen will become dark on the screen change batteries message will appear. can...
You can use rechargable cells with high current( mA) rating. So try and use any rechargeble cells with above 2000mA . Also you can use a rechargeable adapter externally to charge these cells.
Aug 17, 2011 | Canon PowerShot SX100 IS Digital Camera
Canon T90 haven't used camera for 6 months, new batteries in camera will not function at all, was 100% O.K. when last used, any ideas please
Check to make sure the replacement battery or batteries are correctly installed. There should be some type of diagram in the plastic or label showing the correct orientation. IF the batteries are correctly installed and the T90 still persists in not operating then remove the batteries and clean all the terminals/connections either with a new rubber on the end of a pencil. I have as much as I hate to admit left batteries in my gear and had to resort to abrasive paper affixed to a new pencil to get down inside the battery chamber to clean the contacts. Also and I hope this is not the case the T90 has an internal battery and if this is dead then I'd suggest sending it to a repair facility. Most service places will clean lub and adjust and replace the battery for about $100.00 and Yes the camera is worth it even today in our digital world
Nov 24, 2010 | Photography
Canon Powershot S2 IS Digital Canera says to change the batteries even with new batteries in
Check that your battery terminals are clean and that none of them are loose. You may also need to change an internal battery, the one that saves the date & time.
Apr 10, 2010 | Canon PowerShot S2 IS Digital Camera
Canon SX 100 IS won't go on, at all. Not yet 2 yrs old. Just... dead. Changed batteries, cleaned terminals, nothing works. any ideas?
My Canon SX100 IS doesn't power on. I tried using several batteries and also cleaned the metal battery contact but nothing works. Any advice ?
Sep 22, 2009 | Canon PowerShot SX100 IS Digital Camera
My SX 100 camera says change batteries
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Sep 02, 2009 | Canon PowerShot SX100 IS Digital Camera
Powershot SX100 low battery symbol with new batteries
Hi!
If you're sure that the batteries are full, then the power board has to be changed. It's the first board under back cover, with the buttons on the other side of it. Contact your local Canon service center. If they ask very much, you can contact me toms.safranovs@gmail.com and I can give you a price - I have access to new Canon parts.
Tom
Jul 28, 2009 | Canon PowerShot SX100 IS Digital Camera
Cameras Logo
289 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
