Question about Hitachi C29-F800S 29" TV
Streched screeen! My TV screen is streched from both sides, for example i can't view the logo of the channels because the picture is streched! it's just like when you strech your PC screen. is there a code to inter so i can adjust this problem? i don't seem to find anything to fix it??
  • Moe Sammak Jan 15, 2007
    it didn't work!
    the guy who made the screen strech horizentaly told me that he was clicking on the tv's remote control then this happened! i can view the news bar because the vertical didn't change only the horizental. just like the computer screen
    Novelist:
  • 192 Answers
I see more of this out in the field everyday. If you have a cable box or satelite receiver, then look for a format change on it. Usually in that components menu. If, you still cannot find the answer, reply back with the type of unit, if any, that control the channel on the set. I hope this helps.
Posted on Jan 13, 2007
My mitsubishi vs60607 the picture is too big for the actual screen. it's as if i set it to zoom mode but it does not have a zoom mode
Hi:
If you are using a cable box connected to the television for viewing channels, the box has a screen format button on it make sure its is not in zoom mode also. Check the box's remote for a button labeled format or Aspect or screeen.
May 17, 2011 | Mitsubishi VS-60607 TV
How do I adjust my emachine monitor to display a more realistic picture. It is too wide and stretched out.
Check your graphics/desktop settings for the screen resolution - it should be set to the monitor's native resolution, which is 1024x768.
Dec 03, 2009 | E-Machines eMachines Monitor E15T4
On some channels, the 16:9 channel fills the whole screen (which I want) on othrs, same resolution has grey bars on both sides!! Hate it.
Unfortunately, this has to do with the way each channel is broadcast. Some have gone to 16:9, but some have not (even those in HD--See ESPNHD for one example). Most TVs have a way to "strech" the picture somewhat so you can fill more of the screen, but of course then your image may be distorted. I agree that they grey bars are annoying; I wish they would go to a true black.
Sorry I couldn't be more encouraging. Enjoy your TV!
Sep 13, 2009 | LG 42LP1D 42 in. LCD HDTV
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
PS3 streches off the TV Screen
Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode so that it can be viewed via rca/scart connection.
Aug 17, 2008 | Sony Playstation 3 (PS3) Console
Picture is a little fuzzy and does not fit the screen
Good Day, mopar69;
Try this and if does not work, call SONY TV with Model and Serial NUMBERS, this sounds like you may have a defective light engine, and they are having problems with them, and they , Sony, are covering that device.
Restoring unit to Factory Preset Condition
1) Power off the set (set is now in Standby Mode).
2) On the remote, Press DISPLAY, CHANNEL 5, VOL +, POWER.
3) On the Remote press CHANNEL 8, ENTER.
4) Wait until Initial Setup is displayed.
5) Turn off TV sets power by the Remote or Front Panel button.
6) WAIT AT LEAST 3 MINUTES UNTIL THE LAMP COOLS DOWNS BEFORE UNPLUGGING OR DISCONNECTING THE AC FROM THE TV. If the set is not allowed to cool down the lamp may be damaged by excess heat build up.
I hope this was helpful, Good Luck, big IRISH.
Aug 05, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
My Picture is clear in the middle but is blurry on both sides ?
Sounds like a "filter capacitor" in your power supply. This is probably the largest capacitor on the main board and should be near where the power cord enters into the tv. A capacitor is round and tall, sort of like a miniature cattle farmers grain bin. Take it out and order a new one. You will need to write down two things: the voltage rating and the number of microfarads denoted by the symbol "u". For example, a "2500u at 250 volts. It will have two pins soldered into the board. Desolder, remove, and replace and resolder. Keever
Mar 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Hitachi C29-F800S 29" TV Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
