Question about Sony Handycam DCR-HC32 Mini DV Digital Camcorder
No Sound when Capturing
There is no sound when the camcorder is connected to the Windows Computer via USB cable. I have Windows XP. I tried USB Streaming Tool as suggested by the Manual to select another audio device but it did not work. Suggestions, anyone?
Ah. This happens to me sometimes. Well, for some reason it always works when i first open USB streaming tool( this program is not for recording)use the program to edit the video, like to fix brightness etc. Then open capturing tool. This is what you use to capture the video to your computer. What i do is to press the play button in the program, not the capture button. The video on the camcorder and the video on your screen should start playing. I do this just to test the video if its gonna have sound or not. Then you rewind the video by pressing the rewind button in the program. After that press the capture button. Sometimes it records and you don't hear the sound on the computer, I'm not sure but maybe after its captured into the computer, the video will have sound. If you do record, but with no sound, record about a minute and then stop it. Go to where you saved the video and check if there is any sound. Hope this helps you. Sorry if it's kinda confusing because i don' use the program no more. I use a DVD recorder which you connect your camcorder to the DVD player and it burns the video directly to a DVD. Its much mroe easier but you can't play around with it on the computer.
Posted on Jan 27, 2007
I have an August VGB100 and Im trying to convert Hi8 tapes to DVD using a sony handycam. I cant get sound on the computer when Im capturing.
Im not sure about your computer setup. Are you capturing via usb or have dedicated video capture device? Do you have sound when connected camera to tv. Does your video capturing device require to supply sound separate for example from camera headphone jack to video capture device?
Sep 10, 2018 | Sony Video Cameras
Usb handy cam is invalid when i connect my camcorder to my pc
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.(An i.LINK is a black D shaped connector with 4 or 6 pins. The type ofcable to be used will depend on the i.LINK port of your Computer. TheSony Camcorder will have the 4 pin i.LINK cable and if the computer hasthe 6 pin i.LINK port, then you may have to use the 4 pin to 6 pini.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
Ifyou are using a Windows XP Operating System then you have to installthe USB Streaming Driver in the Computer from the supplied Softwaredisk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
NOTE: If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
Oct 01, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
PC with Windows XP will not recognize DCR-HC96 Handycam, and I don't have the software disk that came with the camera. Help
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
As you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video. The i.LINK port is also called IEEE 1394 or Firewire port.
An i.LINK is a black D shaped connector with 4 or 6 pins. The i.LINK cable is an optional accessory for the Camcorder. You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your Computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Sep 29, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
I have a sony dcr-trv 22e camcorder and i am not able to transfer the images to my laptop via usb,the images are not captured and the i get the cption that that device not detected.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer using i.LINK cable.
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Good Luck!!!!!!!!!!!!!!!
Sep 17, 2009 | Sony Video Cameras
PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Mar 17, 2009 | Panasonic PV-DV103 Mini DV Digital...
ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Nov 07, 2008 | Video Cameras
I rty to connect my DCR-HC18E to the computor via usb but it doesn't work
What Windows (XP or Vista) your are running in PC?
Is there any error message comes when you connect Sony DCR-HC18E with PC?
Does PC sounds Ding when you connect camera at USB port?
Reply on above will help me to provide you assistance.
Oct 27, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Can not get sound when capturing video
hi,
You have to use a firewire cable to capture video.With USB you don't get sound
May 17, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
No sound after capture on computer
Can you tell my from the menu on the camera how you connected it to your computer?
Apr 02, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Sony Handycam DCR-HC32 Mini DV Digital Camcorder Logo
120 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
