Question about Maytag 30 in. CSE9000 Electric Cooktop
Maytag CSE9000 Electric Cooktop, The surface ON LIGHT will not turn off / go off - even when the cooktop burners are in the off position.
They may stay on until the burners cool off. To indicate a hot surface.
Posted on Jan 23, 2007
None of my burners will turn on
Is there a place where there are fuses? try replacing any burned out fuses
Oct 16, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
How many amps is the electric cooktop
The usual amperage rating for a cook top is 30 amps. There should be a manufacturers label that states the amperage of the unit. It may be on the back or on the edge of the unit.
Jan 05, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
The cooktop indicator light on my Whirlpool range, model RF265LXTY, won't go off, all of the knobs are in the OFF position. The hot surface light is off.
most cook tops the light that maches the burner is on if sw is on . if light doesnot fo off replace that sw . if only one light for all burners you will have to fint the shorted one.. good luck mm ..
Dec 12, 2009 | Whirlpool RCC3024 Electric Cooktop
The heat indicator light does not turn off even when burner is cold
It is either the control for that burner or the sensor on the burner. have to check with a meter to verify which one it is.
Eric
Jul 16, 2009 | Maytag MEC5430BDS Electric Cooktop
Maytag MEC5430 cooktop burner indicator lights not working
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
Jun 12, 2009 | Maytag MEC5430 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
637 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
