Question about Acer Aspire One AOA150-1570 Notebook PC
Aspire One NO turn on at all
My Acer Aspire One no Turn on at all.
I try with battery or adapter power nothing.
I changed adapter but still nothing.
It's looks like total death.
  • 2 more comments
  • antonio18201 Nov 27, 2008
    Yes its new
    I'll try to turn it back
    any way thank you
  • Anonymous Dec 31, 2008
    I bought my "acer one" brand new out of the box and it wont stay on for more than 30 seconds even after leaving it to charge for an hour with the power adapter plugged in. The unit also says that its charged with its green led. Overall Im un-impressed so it will go straight back in the morning. I dont want to fiddle with pc´s any more because Im tired of all that now. You would think that they would check all this when they make it.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    this is anew computer isn't it?
  • Acer Master
  • 4,806 Answers
While the laptop is still under warranty do not try to open it! I would recommend that you take the laptop back straight away and have them replace or repair it. Its your right as a consumer.
kind regards
Posted on Nov 27, 2008
  • 458 Answers
You need a DC Jack Repair/Replacement..
your dc jack is the port where your AC Charger plug plugs in to on the laptop.. They can Short out over time and the solder that connects the positive/negative pins burns off which causes the power to short out ... which in turn cuts off power connection to the laptop and can cause motherboard damage if not repaired..
Acer 5733 will not turn on
No solution, mine does the same exact thing but blinks orange five times. I got an error message that said click to fix it. I did it and the computer tried to reset itself but simply died. With brick cord out...nothing happens. Same with battery same with power cord in. The battery was fine. It may have died during a forced windows update. I hope someone comes along otherwise it's "buy a mobo" and buy a battery and so on....
Sep 06, 2012 | Acer Aspire 5733Z-4633
My acer aspire one wont turn on. the screan doesnt got switched on. pls help?
Does the power light comes on? Try a power drain. Disconnect the adapter, remove the battery, press and hold down the power button for 10 seconds. Put the battery back and the adapter and try to turn it on. Still no display? Take it to an Acer repair center.
Dec 21, 2010 | Acer Aspire One PC Notebook
I have an Acer Aspire 7736z which will neither turn on or charge. When I plug the power adapter into the laptop the LED light on the power brick turns off.
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Oct 24, 2010 | Acer Computers & Internet
Hi. My acer aspire 5735 doesnt turn on. I turned the laptop off as normal however when i came to go back on it just wouldnt turn on. The charge light stays on to show whether the battery is being charged....
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Oct 23, 2010 | Acer Aspire 5735 Notebook
I have an Acer aspire 5050 and when i try to turn it on i hear the fans starting but nothing hapens on the screen. i tried to conect it to a pc monitor but it didn't work. I think there isn't any video...
hello gligor,
try this.
Turn Off Laptop
Remove the Power Adapter Pin
Remove the Battery and leave the Laptop Idle without Power n Battery for about 2-3 Hours
Fit the battery again and connect Power Adapter and try again
Feb 04, 2010 | Acer Aspire 5050-3242 Notebook
I have ACER ASPIRE 2920, the power suplly can't turn ON
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Nothing shows on the screen when the power is turned on. I have changed the inverter but it did not solve the provlem.
Dec 19, 2009 | Acer Aspire 5100-5033 Notebook
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
313 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
