Question about Philips ProScreen 4750 Impact Multimedia Projector
Image problem with projector ""ghosting""
My projector is now showing a ghosted image which is like watching with double vision. I have checked lamp life and has loads left any ideas on solution greatfully received
3 Suggested Answers
  • 449 Answers
SOURCE: Ghosting Image
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
Posted on Sep 21, 2008
  • 51 Answers
SOURCE: i have a lc4750 proscan
most likely the mirror has moved or a lense has come out of its groove.
Posted on Dec 08, 2008
SOURCE: Philips bsure sv1 projector
press menu, then picture, select mirror, then choose the "Aa" which appear to be the right way up for you, then press ok.   Done!!
Posted on Jan 04, 2009
0 characters
1 Points
Ghost-image on VPL PX31
There is dust in RGB Panel,that ghost image is actual dust.It need to clean.
Mar 16, 2010 | Sony VPL PX31 Multimedia Projector
My Epson Powerlite 5350 has a ghost image. Any recommendation on how to adjust the projector to remove this symptom?
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Jan 24, 2010 | Epson PowerLite 5350 Multimedia Projector
Ghost image in different color from main image - text appears "doubled"
Use the remote to access the menu and you'll be able to POSITION the colors horizontally and vertically .
You should be able to align with the other colors to make it sync'd.
Dec 16, 2009 | ViewSonic PJ551 Multimedia Projector
Double vision my NEC MT1055 lcd projector has double vision on the menus - looks like the menu was burned in a half in to the left
looks like one of your lcd panels is ghosting. If remember correctly your going to be asked to replace the whole prism.
Aug 28, 2009 | NEC MultiSync MT1055 Multimedia Projector
I have a 61 in sony that is projecting an ghost image.
May I know exact model number and brand name of your TV or Projector to help you.
Aug 16, 2008 | NEC VT465 Multimedia Projector
NEC vt460 Projector have a ghost problem on the screen
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Dec 16, 2007 | NEC VT460 Multimedia Projector
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Philips ProScreen 4750 Impact Multimedia Projector Logo
308 people viewed this question
Top Philips Multimedia Projectors Experts
Lawrence Oravetz
Frank Russell
Frank Russell
Are you a Philips Multimedia Projector Expert? Answer questions, earn points and help others
