Question about Zenith XBR616
How do I record from a videotape to a dvd - Zenith XBR616
You need the cables to hook your VCR to your PC and also a decent Video program that allows you to import a file (The Videotape recording) to the program, and burn it from there.
Posted on Nov 27, 2008
Samsung DVD-V3650 Combo Player ejects most videotapes without playing them
You can only compensate for minor scratches. As for the vcr side the rollers could be dirty or the brake worn out. The tensioner may be too sensitive as well. Basically the mechanism probably needs servicing.
Sep 06, 2016 | Samsung DVD-V3650 DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
I have a sylvania Video cassette Recorder/DVD player. Is there a way to copy the DVD onto videotape with this machine
It depends what you want to copy on DVD on to the video. If it's a commercial film, forget it! The machine/disc will have macrovision on it which will destroy any transfer to video. Otherwise there should be a button that says copy or dub that will let you record other types of DVD recordings to tape. But I can't understand why you would want to as the loss of quality would be bad.
Dec 06, 2009 | Sylvania (SRDD495) DVD Player/VCR
Panasonic DMR ES15, cannot record coywrighted vhs tapes onto dvd.
Try this:
If you have another VCR system (Master) you can connect it from the master to the Panasonic DMR ES15 (slave). Insert the copyrighted tape onto the master VCR system and insert a empty VHS tape on the slave system. In the slave, record from the master. When done, you can record from the videotape you have made from the master tape, to the DVD recorder.
If you still have problems, please contact the manufacturer of this model.
Aug 03, 2008 | Televison & Video
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
Can't record a program with videotape
Try setting the clock again paying close attention to AM and PM settings as well as everything else. REC/OTR is for recording "on the spot". Make sure unit is in proper mode with the DVD/VCR button. Customer service number is usually on a sticker on these units.
Mar 10, 2007 | Sansui VRDVD4000 DVD Player/VCR
Can I transfer videotape movies onto DVD media using the Hitachi DVD-Camcorder?
Yes, and it is highly recommended to do so. Hitachi’s DVD-Camcorder has an advanced analogto-digital conversion system. By using the analog Audio/Video input on the camcorder, the tape based information is converted into digital data and is then recorded onto the DVD disc. See manual instructions for switching input from Camera to Line-In.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Zenith XBR616 Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
