Question about Vacuums
Makes a clicking noise and stops after about 5 minutes
  • 5 more comments
  • dardarfi Jan 06, 2009
    My roomba 560 will run for a few minutes but makes a clicking noise while working and then stops and says to clean the brushes.  We have cleaned everything we can find and it keeps on happening. Help!
  • fullcount9 Jan 18, 2009
    Same problem. Cleaned everything, runs for a few minutes, then says clean brushes. Very annoying considering this is not a cheap item.
  • caseycork Jan 20, 2009
    My roomba makes the same clicking sound that everyone elses does! The brushes aren't spinning and the vacuum isnt working. The gears were making odd sounds before the brushes stopped spinning. I cleaned everything but the gear box. We as CUSTOMERS should not have to become repair men/women....I've only had this thing for 2 months. The warranty is nice except for the fact that it takes months to get anything accompished for the warranty company!
  • badgeris Mar 31, 2009
    Same problem as others have described...I have cleaned the the brushes THREE TIMES today (thorough cleaning, screws out, etc), in the past hour, but no improvement. It's as clean as when I bought it, as far as I can tell. The only thing I did notice is that there is some hair/fuzz around the axle of the little pivoting wheel, which I cannot fully clean off (although I tried with scissors & tweezers). I may try going without the rubber brush to see if that will work. Otherwise, now I know why they have Roombas refurbished on Overstock. SIGH.
  • jkee002 Apr 26, 2009
    We have the same problem. The roomba clicks as it moves along and then stops and beeps twice to clean the brushes. The brushes are thoroughly clean but the problem continues.
  • elenakitty May 14, 2009
    kiorash's answer was completely right, and it says so right in the manual, but i checked online before resorting to the manual, because often i can find the answer faster online to a precise problem. thanks kiorash!
  • juro007 May 16, 2009
    kiorash - Thank you. It seems to work perfectly! I almost took apart the gearbox while cleaning! :-) you saved me a lot of time and trouble!
Ladies and gents,
I can't bear you moaning like this honestly! Here is the solution-
get your self a tiny 4 headed (philips screw driver) and test your ROOMBA
1) REMOVE THE RUBBER BRUSH AND RUN ROOMBA ON JUST THE BIG BRUSH
2) CHECK IF ROOMBA STARTES CLICKING AND ODES THE SAME THING
3) IF NOT PUT THE RUBBER BRUSH BACK AND REMOVE THE BIG BRUSH AND THEN CHECK IF CLICKING CONTINUES.
4) ONE OF THEM WILL BE THE CULPRIT. REMOVE THAT BRUSH AND YOU WILL SEE TWO 4 HEADED(PHILLIPS) SCREWS ON EACH END OF THE OFFENDING BRUSH- LOOSEN THE SCREW AND YOU SHOULD SEE LOADS OF HAIR AND FIBER ROUND THE BEARING.
5)TAKE THE BEARING OUT AND REMOVE ALL THIS HAIR-YOU WILL BE SURPRISED HOW MUCH THERE IS
6) PUT THINGS BACK TOGETHER AND ROOMBA WILL RUN LIKE NEW
i PROMISE!
Posted on Jan 29, 2009
I have the Roomba 530, the white model, and my solution was to clean the gear box. Here's how I did that.
1: take off yellow spinny-brush
2: take off gray plastic undercarriage plate
3: unscrew 4 tiny phillips head screws that hold the whole brush carriage assembly. These screws can't fall out. Go ahead and remove the brushes.
4: unscrew a few (4 maybe?) more screws on the gear side of the brush assembly, on the side with the white square parts. Be careful, because these can fall out, and they are slightly longer than the following-
5: unscrew the screws holding the gear box closed. Once again, don't lose these screws. Mine was chock-full of fur, hair, dirt, general nastiness. I got out a sharp knife (careful!) and cleaned each gear and then both sides of the gearbox with the knife and a paper towel.
6: Put it all back together!
The whole process only took me ~15 minutes, but I had previous experience taking apart most of the roomba minus the gearbox. Good luck!
Posted on Apr 19, 2010
The problem has got nothing to do with cleaning the machine. The problem is an error in the production. The wings on the small rubber roller should be swept back so that they sweep across the floor during cleaning.
On the noisy rolers, the wings are facing the other way round, and they hit the floor with a forward pointing edge, in stead of a back swept edge . This gives the beating sound. especially on hard wood flooring.
The solution is to change the roler. I got a new from the importer in Denmark, when I told them about the problem.
Klaus Lund
Posted on May 24, 2009
I have the same problem, though I don't know the actual fix, one way to get it to work fairly well is to remove the rubber brush (the smaller one) and let it keep going. It seems to clean just as well from what I can tell.
Posted on Jan 11, 2009
We have a 577 - Solution # 2 worked for us - thanks heaps! Lesson learned: read the manual THOROUGHLY or Google ;-) !!
Posted on Jun 06, 2010
2 Suggested Answers
  • 27 Answers
SOURCE: my roomba 550 makes loud clicking noises and stops
pull brush rollers out.pull funny lookin yellow ends off and clean hair ect.out .also pop out front wheel and clean
Posted on Aug 06, 2010
How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
Jan 23, 2017 | Vacuums
My DC31 just stopped working while I was vacuuming my wood floor. Is only 2 mths. old. I bought this for the versatility so I don't have to lug my big Dyson up and down my stairs. The battery was
Don't overlook the obvious. My DC31 just stopped working when I was using it. No lights, no noise, nothing. After poking around for a a couple of minutes, I removed the battery and then re-inserted it. I gave it a good tap with the palm of my hand to make sure it was seated properly. Everything worked after that.
Jun 02, 2012 | Dyson DC31 Animal Bagless Handheld...
Rumba making Clicking noises - stops It has been cleaned.
even if the 2 brush rollers are clean you need to pull the small yellow ends of the roller off [the funny lookin ones].hair ect. get jamed in there .use a knife or small screw driver to pull the build up out.hope this helps
Jul 13, 2010 | iRobot 53501 Roomba 500 Series Vacuum...
IRobot 560 Roomba making thumping/light clicking noise.
under warranty take it in for warranty repair or exchange
you try to fix it and the warranty is voided
just tip it upside down and check for threads wrapped around brushes and rollers / wheels
Nov 22, 2017 | iRobot Roomba 4210 Bagless Robotic Vacuum
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
"Please clean Roombas brushes"
Same thing happened to me. After "cleaning" the brushes and emptying the filter several times, I realized that the brushes were not properly secured. One of the yellow fasteners needed to be pushed closer to the middle nearer to the brushes. It was not secured properly. When I did this it fixed my problem.
Dec 20, 2008 | Roomba Robotic Floor Bagless Vacuum
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Hi folks, my beam vacuum makes a very loud roaring noise quite often. the problem started when i was vacuuming up a quantity of vermiculite from my chimney. i think i overloaded the vacuum i think and...
If the filter bag is bad and didn't trap all of the dust, then it got into your motor, so you may have a problem with your motor now.
Apr 20, 2008 | Vacuums
Vacuums Logo
2,777 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
