Question about Kenmore 72202 / 72204 / 72209 Top Freezer Refrigerator
Water under drawers, condensation on top of freezer
Water keeps on pooling under the fruit and vegetable drawers and I can not figure out where it is coming from. Also, there is a lot of water drop stalagtite or stalagmite looking things forming on the top of the freezer compartment. Unit seems to be functioning just fine.
  • Pamela Carltock Jan 14, 2007
    Well what you said made sense but I couldn't locate the drain hole after I cleared everything out of fridge. The back plastic piece that covers it would not come off. I am hoping that by cleaning off built-up ice over that area and removing some of the trash that may have been blocking flow, it will help. I did as much as I could, even researched schematic for this model but could not find clear way to get to drain hole. Bought it as a floor model and I'm not sure I ever got a book with it. Thanks.
    Well catriver - doing what I did, did not help. This morning I had all new puddles under my bins. By the way, what the heck is a calrod heater? Thanks again
Water collecting on the top of a freezer, I have to wipe it every week, it is on the outside of the freezer, on top of the formica surface. Please Help.
Posted on Aug 10, 2008
    President:
  • 878 Answers
Harrtock, what's happening here is that your defrost drain in the freezer section is clogged or frozen over. When the unit goes into defrost, some of the water is running down the air duct to the refrigerator and gathering under the drawers. You need to clear out the freezer, remove the rear panel and clear out the defrost drain. You can do this by pouring hot water over the drain hole with some sort of baster. To prevent this from happening again take a piece of copper wire and loop it over the calrod heater on the evaporator and push the other end into the drain hole. Now when the heater comes on in defrost the heat will keep the drain hole from freezing over...Catriver..post back.
Posted on Jan 13, 2007
Worked for me. Thank you. I was having this problem for months and could not find an answer until now. Thank you sooooo much for having this site.
Posted on Aug 19, 2007
Where is the drain hole for this model
Good Afternoon Friend,
I understand that you are looking for the drain hole on your Frigidaire refrigerator, model# FFHT1725PS, due to water building up on the shelves inside your refrigerator. There technically is no drain in your refrigerator. There is a drip pan, which collects water from the condenser underneath your appliance. There are some possibilities that are causing the water to build up on the shelves. First, make sure that all containers are covered. Condensation can evaporate from opened containers and create water on the walls and shelves. Secondly, make sure that the drawers that have your fruits and vegetables are completely closed and set to the correct setting. Fruits and vegetables are full of water. Thirdly, check to make sure that your doors are closing and sealing correctly. Moisture can come through an open door or a door that is not sealed correctly. Lastly, if it is hot and humid, make sure that you are not going in your refrigerator many times and holding the door open as well. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FFHT1725PS 16.5 cu. ft....
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water is pooling under the veg/fruit drawers..cant tell where its from. Freezer temp is uneffected, temp appears fine, no condensation anywhere on refrig or contents...The first I noticed it was a week...
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
Feb 17, 2011 | GE J Series 20.6 cu. ft. Top Freezer...
What would cause a refrigerator to collect water under the fruit and vegetable drawers?
hi there, refrigerators have condensation that forms and generally goes down a little hole that is usually under the fruit and vegetable drawers. This water should go down this whole into a condensation pan that is under the refrigerator and then evaporates. Sometimes food gets in the hole under the drawers and keeps the water from being able to travel where it needs to. Try to run a pipe cleaner of something through the hole to clean it out and maybe a very small amount of HOT water. If there is no hole there, it is unusual and it is possibly something else. This is usually the problem I have. Hope this helps!
Jan 15, 2011 | Kenmore Refrigerators
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Water running out from under vegetable and fruit
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Hook the other end , around the glass rod (defrost heater) carefully , to avoid breaking the glass , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 01, 2010 | Refrigerators
Kenmore 72202 / 72204 / 72209 Top Freezer Refrigerator Logo
1,364 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
