Question about Beyerdynamic DT 531 Consumer Headphones
Replacement foam for Beyerdynamic DT 531 Consumer Headphones
Hello, The thin foam discs -inside- my headphones has disintegrated. Have you any idea were I can order replacements? Beyerdynamic's website is useless for service!
Thanks!
  • 87 Answers
Same issue with mine, unfortunately this is par for the course with petroleum based foams. Fortunately, the headphones themselves are pretty easy to take apart. Slip a small flat screwdriver in the crease between the plastic casing and the black rim that holds the blue/gray velvet ear pad. The entire pad assembly pops right off and then you remove the old foam disc from inside. Once you have them apart, you can replace the foam with more thin foam obtained from ebay or wherever, or some other soft material. FYI, BeyerDynamic's customer service is actually pretty good if you call them on the phone. My cat chewed through my cord a few years ago, I was able to call them up and order an OEM replacement. It cost me about 8 bucks, I was able to solder it up and it worked just fine. MY problem is that the foam padding INSIDE the velvet rings is losing its pliability. I've removed the rings and washed them a couple times (they do get pretty filthy). I will probably make a couple small incisions in the back of the material itself (hidden inside the set itself when together) and restuff with some cotton batting.
Posted on Jun 11, 2009
I have the same problem with a pair of Fostex Headphones. I have taken them apart and I have removed the rubber type ring that the foam fits over.
I am going to order a cheap pair of thin foam Headphone ear covers from Ebay. (They are available in various sizes) and stick the foam to the ring and follow that
by sticking the ring back in. Should work if the foam is thin enough. What do you think?
Eddie
Posted on Jan 03, 2009
Same problem here so I just took my Koss pro 480 headphones apart and covered the whole "ear ****" with a pellon type fabric (interfacing fabric) then snapped it back on with the fabric tucked under the rim. We'll see how well this works for me. With new ones selling for over $80 I hope this works.
Posted on Jan 07, 2010
  • 146 Answers
I don't think they do replacements for those kinds of things.
If Beyerdynamic wont help with this than I don't see how you are going to get these thin foam wires especially if they are for headphones they will just want you to buy new ones.... I think your only option is to buy a new headphones
Posted on Nov 27, 2008
How to to re-wire beyerdynamic T51p drivers and complete cable replacement
beyerdynamic Spare parts - Headphones & Headsets
north-america.beyerdynamic.com/shop/hah/spare-parts.html
Items 1 - 40 of 53 - Cable Assambly for DT 108 / 109 ... Ear cushions pair, black, for T 51 p ... Ear cushion / black velour / one set / replacement ear pads for T1.
Dismantling the Beyerdynamic T1 for the 1st time - YouTube
? 5:21
https://www.youtube.com/watch?v=XC72mCFOIWo
Jun 19, 2013 - Uploaded by Jason Rhys-Thomas
Here is a quick vid of the dismantling process for thebeyerdynamic T1 - I ended up having ... I will be re-cabling them with SPC shielded cable.Missing: drivers
Dec 16, 2015 | Beyerdynamic T51P Tesla Headphone - Silver
When i plug the headphones to my MacBook Pro i cant get the exact sound of the song. it sounds weird.
if you are using itunes go to equalizer it should be in one of the options menus (dont uses a mac i use linux sorry i cant be of more help)
Mar 06, 2011 | Beyerdynamic DT 231 Consumer Headphones
I need a replacement capsule for Beyerdynamic DT-150 headphones
I'd start here http://north-america.beyerdynamic.com/service.html
you should be able to find local/area outlets or order direct.
Nov 09, 2010 | Audio Players & Recorders
The inner foam filters have desinigrated and need replacement. Is this possible?
If you remove the pads you should be able to peel away whats left of the foam. All you really need to do is find some foam to replace it. Shop around take a piece with you at, say a fabric shop or something dealing in foam. You might need to cut it to size, then just glue it in place.
Jan 07, 2010 | Beyerdynamic DT-831 Consumer Headphones
Sound not coming out of headset.
u probably pulled the wires off the connection or pulled the wires from the head set check those and resolder where required
Nov 30, 2009 | Beyerdynamic DT 231 Consumer Headphones
I tripped on the cord, now no more sound.
Here is a link to how to fix them:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/ Please let me know if this helps.
I have a set with one ear piece working
I don't have one, but are you sure the ear piece itself is bad? Usually, the problem is in the plug, cord, or termination at the ear piece. Troubleshoot with an ohmmeter (pocket DMM has one) and repair with a soldering iron.
Jun 25, 2009 | Beyerdynamic DT 531 Consumer Headphones
Beyerdynamic DT 531 Consumer Headphones Logo
1,027 people viewed this question
Top Beyerdynamic Audio Players & Recorders Experts
Ben Armstrong
Alan W Kelly
Alan W Kelly
Are you a Beyerdynamic Audio Player and Recorder Expert? Answer questions, earn points and help others
