Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Pro heat 2x no water coming out carpet part / hand tool either
I cleaned away any fibers from the parts. If you press the bottom of the water tank the water will come out. It is something once you sit it on the base of the machine.
  • 3 more comments
  • msjtravis Dec 02, 2008
    i have no water coming out on the floor or the shampoo! Only used once. please help i have pets.
  • jomareecrow Dec 07, 2008
    I will never buy another bissell product. My first bissell cleaned for 2 months and stopped. I took it to a bissell dealer that told me my motor burned up. My second bissel was a vaccuum cleaner that would not pick up anything and the store would not take it back even for a tradein. They gave me an 800 # where the people where laughing and had a jolly good time while I tried getting help. I got an id # to give the store to get a refund. Store said no they could not do that. So I am stuck with a vaccuum cleaned that does not work cause I did not keep my store receipt. My daughter gave me another bissll and it will not pick up water. Whats with the bissell line. I will warn everyone I know not to buy bissell.
  • mlla Dec 12, 2008
    Was working just fine then the water stopped coming out. I'm seeing this a common problem. There needs to be a fix!
  • mrms Dec 27, 2008
    I have a Proheat 2x model # 8930. Been working great, but this time around the water is just not coming out of the machine. This seems to be a fairly common problem with maybe the pump going out? Has anyone replaced the pump themselves and, if so, is it fairly simple and where would one get the replacement part? If anyone has had their pump replaced by an authorized service center, can you share what that might cost and if you've had it hold up afterward? Thanks!
  • Everyboysmom Feb 22, 2009
    second machine same problem
    Problem Solver:
  • 3 Answers
In case any of you are still trying to figure this out... I took mine into a repair shop and had the pump replaced for $66. The repairman had 6 other machines in his shop when I bought mine in. He said the pump goes the minute it runs dry, so if you get yours fixed, or know anyone else with one, make sure to KEEP THE CLEAN TANK FILLED AT ALL TIMES!
Posted on Apr 04, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I have a Bissell preheat 2x which I have had for about 4 years. The cleaning solution and the water doesn't come out when I start to clean my carpet. I've unplugged the holes and cleaned the cleaner a
Clean the filters? Check your- User's Guide for locations. Or Contact Consumer Care at 1-800-237-7691
Filters are usually located under the Clean Water Tank Cap (looks like a screen) and The Flow Indicator Cap. Hope that helps.
Sep 09, 2014 | Bissell Vacuum Pro-Heat, Pro-Heat 2 6960W...
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 2x - will not spray from the hose or the bottom of the unit
carpet fibers may be clogging the spray. clean the area around the brushes (remove the water and formula tanks)
Sep 04, 2008 | Bissell Vacuums
Shampooer tank not working
Most times there is a problem with the cap and insert at the bottom of the tank, part #2036675. Either that or the tank isn't sitting flush and down all of the way, leaving a gap. If this is less then 1 year, then it is under warranty.
Nov 10, 2007 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
271 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
