Question about Apple iPod nano
Generation 2 Ipod won't turn on
When Ipod turns on there is a white screen and when you move the menu button you can hear the clicks
    Scholar:
  • 42 Answers
Your screen probably needs to be replaced. They do go bad. Did your iPod get wet or was it dropped? This will also cause the screen to go bad.. Good news is that the screen can be replaced. The bad news is that it costs about $60. Hope that helps.
Posted on Dec 19, 2008
Generation 2 ipod touch will not do anything
Posted on Aug 28, 2009
Faulty screen for iPod 4g
If you notice that your iPod screen has turned white and is completely unresponsive you can unfortunately assume it is a software issue.
(If you've damaged your iPod, it's a hardware issue that most likely cannot be fixed.)
Sometimes the iPod just freezes up much like a computer and you have reset it to get it working properly again.
If your iPod ends up with the "white screen of death," try a hard reset to see if that fixes the problem.
Unplug the iPod from your computer or any other docking power station.
It must be independent of any other device.
Attempt a "hard" reset.
iPod Nano (6th Generation) owners should hold down the "Sleep/Wake" plus "Volume Down" buttons at the same time.
All other iPod models require a two-step approach:
1. Toggle the hold switch on and then off again.
2. Press the "Menu" and center "Select buttons or the "Play/Pause" and "Menu" buttons (depending on your actual model) simultaneously.
Hold the button combination for approximately 8 to 15 seconds until you get an Apple logo.
Allow your iPod to reset itself and turn back on after you see the Apple logo.
Set up your iPod as a new device rather than from a backed-up file once it is restored.
This prevents you from getting a white screen of death again if the problem was in your iPod's setup.
Jul 02, 2013 | Audio Players & Recorders
White screen after it was 30 degrees out side overnite. center button and menu after turn switch to orange then back gets black screen and can hear 2 beeps. press play and center - gets 4 beeps. cant...
Hi You can try the troubleshooting guide below, If in case the troubleshooting guide will not work I highly suggest to contact apple technical support .
iPod Nano 2nd Generation Troubleshooting
The second generation iPod introduced a new design and lots of improvements to the player's technology. The new Nano boasted a new enclosure made of aluminum, a slimmer design with rounded corners, a brighter screen, new headphones and a wide selection of colors. The flash drive made hard drive failure less likely, making these a long-lasting mp3 player option. The iPod Nano can fail eventually, but when yours looks dead, all may not be lost.
Hold and ChargeThe first thing to do if you have an iPod that is not turning on is to check to see if the hold button it is engaged. If it is, slide the button to the left to take the iPod off hold and see if the buttons work. If not, check to see whether the iPod is charged. Try plugging your iPod into your computer or a wall socket. If the iPod does not respond, do further troubleshooting.
RestartAfter checking to see if your iPod is charged, you should try restarting your iPod. Hold down the menu and center button on your iPod until it restarts. You will see the Apple icon. If this does not work, move to the next step.
RetryTry another USB cord if your computer does not recognize the iPod. If the new USB cord works, it was the previous USB cord at fault.
ResetIf your computer does not recognize your iPod, try restarting the the computer. It may be that the software on your computer is at fault, and not the actual iPod.
ReinstallIf your iPod is not recognized by your computer, try reinstalling iTunes. Sometimes a fault in the iTunes software will prevent the iPod from being recognized by your computer. Download the iTunes software from the Apple website and install on your computer.
RestoreIf your iPod is not responding, you may need to restore. If your computer recognizes your iPod select your iPod from the left menu in iTunes. Click the restore button from the menu under the picture of your iPod. Make sure that all of the music on your iPod is backed up somewhere else, as the restore will erase the contents of your iPod.
Dec 04, 2011 | Apple iPod nano
I have a 4th generation pink 8gb ipod nano the
To factory reset on my ipod classic...  slide the hold switch to hold  then slide it back  then press the center and menu button for up to 60 seconds.
Nov 10, 2009 | Apple iPod nano
My ipod screen is blank!! HELP!!!
First try to reset it, do this by holding down the "Menu" button and the middle button for about 7-8 seconds. If it still doesn't work, try restoring it. Plug it into your computer and open iTunes. Now select your iPod in the list to the left, then click the button that says "Restore," it`s located right under the picture of your iPod model.
Hope this helps!
Sep 03, 2009 | Apple iPod nano 3rd Generation
White screen and beeps
Try This next time ....
Not all, but many 5G iPod owners have had issues with the latest iPod updates, I had this problem myself a day ago & was almost ready to send it in for a replacement, some HAVE sent theirs in. Anyways, after updating the iPod the iPod no longer works!! All you get is a blank white screen (White Screen Of Death), 3 beeping tones and you hear the hard drive click. Simply resetting the iPod will do nothing, but get you another three beeps & a click. But to resolve this issue do the following, this had worked for me as well as others...
Extended Reset
1) Move the LOCK to the "ON" position.
2) Move it back to the "OFF" position.
3) Hold the "Centre" button then hold down the "MENU" button until you hear the harddrive make the "click" noise.
4) As soon as you hear the drive "click" press and hold the "Centre" button then press & hold the Play/Pause button, you should then see the Apple Logo" like normal and it should then start up like with no problem.
Apr 22, 2008 | Apple iPod nano 3rd Generation
IPOD Third Generation
try a reset first
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Apr 21, 2008 | Apple iPod nano 3rd Generation
I plugged my IPOD NANO IN TO THE COMP AND ALL **** SET LOOSE, THE IPOD ASKED FOR A RESTORE, WHICH I CARRIED OUT, I THEN EJECT AND ALLS FINE, THEN I RE ATTACH IPOD AND START INSTALLING 1 OR 2 ALBUMS TO...
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Mar 10, 2008 | Apple iPod nano
Apple Ipod Video
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Nov 29, 2007 | Apple iPod MA446LL/A MP3 Player
Apple ipod
  • iPod classic
  • iPod nano
  • iPod mini
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
204 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
