Question about Toshiba Computers & Internet
All of a sudden my computer does not "see" my dvd drive. When i go to device manager, this is the message: Toshiba DVDW/HD TS-L802A ATA Device. Windows cannot load the device for this hardware. The driver may be corrupted or missing (Code 39) I next tried to update the driver, but it says that I have the latest driver. I then tried to plug in via USB an external DVD drive...my computer won't see that either, but it sees any other device that i plug in via the usb ports. what gives, I am lost here?????
  • 6 more comments
  • saintkelley Nov 28, 2008
    restore system did not work and I don't know how to take my laptop apart to disconnect the dvd drive. Anyways, if that would work, wouldn't the NEW external dvd drive that i bought and tried to plug in via USB be seen? It isn't seen either by the computer, even though anything else i plug in via USB (camera, video camera, printer) ARE seen.
    Help!
    it is
    I am using windows vista
    error message says it can see it but can't load it
    it looks like i can't restore to an acceptable date because it will only let me restore to about 5 days ago and my problem has existed for about 10 days.
    Go to the Device Manager > Right Click on the Toshiba DVD then select properties. Go to Driver tab and click on Roll-back driver.
    When i do the above, the roll-back driver option is greyed out and will not let me click on it. When I click update driver, it says that i already have the latest driver
    It took a lot of answers, but i finally got the one that worked! Thank you!!
    President:
  • 1,257 Answers
Easy steps to resolve the issue that you are facing "
As a default "RUN" is not available in start menu.So left click on desktop,now press windows key + R simultaneously to open "Run" command box.Now in "RUN" type regedit and press enter key.Now registry will open.Now left click on "HKEY_LOCAL_MACHINE" in left pane of registry and press "control key + F " simultaneously to open "FIND" box.Now copy this text as it is " 4D36E965-E325-11 CE-BFC1-08002BE10318 " without quotes and paste in "FIND" and hit the enter key.After window finds that key you will see "UPPER FILTERS " & "LOWER FILTERS" on the right pane.Just right click on them and delete it..Now goto device manager and uninstall "CD/DVD ROM" that's it
Now restart your computer and your issue will be fixed
Posted on Nov 28, 2008
    Scholar:
  • 81 Answers
i agree in some expert says, the things that come up to my mind of your problem is probably that is a virus. if you have an anti virus then update it or upgrade to latest version.
upgraded free anti-virus can help or fix viruses now a days.
after update and upgrade then scan your PC, and then re install your drivers.
  • Alver Clamonte
    Alver Clamonte Nov 28, 2008
    just adding something have you check the cable of your dvd? make sure that it will firmly fix the sata or ide cable. both on board and in your device. and make sure turn off the power and unplug the cord before doing this.
  • 105 Answers
The device is not working properly because Windows cannot load the drivers required for this device (Code 31).
A driver for this device was not required, and has been turned off (Code 32 or Code 31).
Your registry might be corrupted. (Code 19)
The most frustrating part is I have had several Toshiba customers call me about having this issue on brand new laptops. The good news is it is a simple fix that anyone can do.
First lets confirm your issue. Right click on “Computer” or “My Computer” in XP. Select Manage and then on the right side select device manager. On the left if you see a yellow exclamation mark next to your drive and were getting any of the above error codes then we have a simple fix.
Go ahead and right click on the CD or DVD drive that has a yellow exclamation mark next to it and select delete or remove.
For Vista click the windows “start” button on the bottom left and in the search box type regedit . You will be asked to confirm your admin account. Just hit next or continue.
Now browse to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
It’s just like browsing through folders so don’t worry about it. if you get lost just start over. BE SURE you follow the path 100% There are many similar files and folders so double check they all match up.
Now that you are at the {4D36E965-E325-11CE-BFC1-08002BE10318} Folder on the right side you will see several entries. right Click and delete the Upperfilters and Lowerfilters. These will be remade once you reboot.
  • 94 Answers
Also, when you tried to update the driver of your DVD, use the option to "Install it Automatically (Recommended)" so that the computer will look for the drivers that is saved on your OS.
  • kagebunshin Nov 28, 2008
    Try removing the Toshiba DVD on the Device Manager, then Click on Action then Select "Scan for Hardware Changes". Try reinstalling the driver. Make sure to do it Automatically since no drivers are needed for the DVD.
    Genius:
  • Toshiba Master
  • 1,250 Answers
Reinstall the OS using the restore cd/dvd that you have then check
    Sergeant:
    Champion:
  • 251 Answers
Try this go to if there is a up date for u updateshttp://www.tacp.toshiba.com/resource.asp?resourceid=71
Posted on Nov 27, 2008
    Scholar:
  • 135 Answers
Please check that your bios detect your dvd if not then change dvd jumper sitting if yes then try to restore you system.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls download, expand and merge *.reg contents of this file. They are meant to restore missing CDs & DVDs if you are using Windows XP.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 28, 2008
    Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
    The posted link would likewise work for Vista, just tried it. Incidentally, should you want to manually perform the fix:
    • click on the start menu;
    • in the search box type in “regedit” less the quotes;
    • expand the HKLM and go to the registry key as above listed;
    • locate in the right panel “UpperFilter” and “LowerFilter”;
    • click on each “filter” key and hit delete;
    • click yes when asked to confirm if you wish to delete the key.
    • Restart Windows.
    Would appreciate further updates.
  • 541 Answers
Make sure the jumper setting is on master
    Sergeant:
    Champion:
  • 291 Answers
1st try to restore your computer tp a earlier date and then try it and it that don't work then go inside and disconnect the dvd drive and reboot then shut off and reconnect the dvd drive and turn back on and it should pick it back up.
be sure to remember to leave a rating / thanks / larryyb
  • Toshiba Master
  • 19,396 Answers
There is no driver for DVDs, this is problably a virus, do a system restore to a recent date.
  • 1 more comment
  • Ginko
    Ginko Nov 27, 2008
    Toshiba DVDW/HD TS-L802A ATA does not require any driver, and you are the second person today with same problem. This let me think that the problem can be a virus.
    Try first following instructions here.
    If that does not work do a system restore to a date before having the problem.
  • Ginko
    Ginko Nov 28, 2008
    You need to change some of the entries on the registry system, if you do not trust doing it yourself call a local technician.
    Here is the solution for this problem (already published): follow instructions here.
    If you cannot do it yourself call a tech, but that is what must be done first.
  • Ginko
    Ginko Nov 28, 2008
    I am getting tired right now,
    You need to do this first, and then we can proceed:
    To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
    1. Click Start
      Collapse this imageExpand this image, type regedit in the Start Search box, and then click regedit in the Programs list.
      Collapse this imageExpand this image If you are prompted for an administrator password or confirmation, type your password, or click Continue.
    2. Locate, and then click the following registry subkey:
      HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution
      There can be many instances of the registry subkey that is mentioned in
      step 2. You must make sure that you are in the appropriate registry
      subkey before modifying the UpperFilters and the LowerFilters values.
      To verify that you are in the appropriate registry subkey, make sure
      that the Default data value is DVD/CD-ROM and the Class data value is
      CDROM.
    3. In the right pane, right-click UpperFilters, and then click Delete.
    4. Click Yes to confirm the removal of the UpperFilters registry entry.
    5. In the right pane, right-click LowerFilters, and then click Delete.
    6. Click Yes to confirm the removal of the LowerFilters registry entry.
    7. Exit Registry Editor, and then restart the computer.
    If that does not work there are more steps, but that should fix it.
    If you do not want or cannot do it, call a technitian, and that is all.
    Goodbye
  • 734 Answers
Check out the BIOS settings,, find out your DVD drive by going to BIOS (as like you search for a new HDD)
  • 3 more comments
  • futureloginn
    futureloginn Nov 27, 2008
    You need to install the latest driver for your device...
    http://www.techspot.com/drivers/driver/f...
    official bits from microsoft:
    Code 39
    Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
    Recommended resolution
    Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
    Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
    On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
  • futureloginn
    use this software to search for missing driver, after search follow direction and download driver... good luck
    http://www.yousendit.com/download/Q01Ic0...
    code and serial to unlock soft
    License Quantity: 777
    License Name: proletfound
    License Code: DGP70-2SRKF-7HZ96-GE9GE-2ZKN7
  • futureloginn
    From Microsoft support site.Code 39
    Personal note:
    Microsoft generally uses a standard driver for all hard drives, so if the procedure doesn't solve the problem, try running chkdsk on the drive.
    Open my computer, right click on the drive and select properties. Go to the tools tab and click check now under error checking. Choose both options. When you restart, chkdsk will run and try to correct errors on the drive.
  • futureloginn
    ok.....
    take a last Try go to the following link that will sure fix your problem---
    http://support.microsoft.com/kb/314060
  • futureloginn
    futureloginn Nov 28, 2008
    Thanks
CD/DVDW ROM drive won't start
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Jan 25, 2012 | Gateway Computers & Internet
Error with a TSST CD/DVDW TS-L532U.
Try uninstalling the device using device manager. Shutdown computer and restart. If the problem persists then you have a faulty DVD/CD drive.
Go to My Computer and right click, select the Device Manager, search for the drive on the right side. Right click and choose Uninstall. then restart. Hope this helps.
Jun 13, 2010 | Computers & Internet
TSSTcorp CD/DVDW TS-L632D ata dvd drive doesn't burn!!! Vista HP
Most of the time MEMOREX brand is not compatible with HP.
Try a diffrent brand and check if it works.
Jun 05, 2010 | HP Computers & Internet
My CD/DVD drive aren't working
Click on My Computer. Go to system information. Click on Hardware. Select Device Manager. On the drop box right click the CD/DVD drive and click properties. Click on Update driver. It will give the information if the driver has been updated. Try running the CD rom. If any problem go to trouble shooting on the properties page opened earlier and follow instructions. If it still does not work then download the drivers from support at HP Pavilion web site.
Apr 19, 2010 | HP Pavilion dv6930us Notebook
K i have a toshba dvdw/hd ts-l802a ata driver 39 issue i have uninstalled reinstalled and to no avail ive been looking for a driver all morning and i cant find one it says that its corrupted or missing...
Have you uninstalled and then rebooted? It may sound an odd question, but if you do not reboot, then all of the associated data is not removed.
Once rebooted, let the system identify New Hardware and then follow the on screen instructions.
Hope that helps
Mar 07, 2010 | Toshiba Satellite X205-S9349 Notebook
How do I install a TSST corp CD/DVDW TS-L632D ATA device
It should just plug in and windows will reconize it.
Sep 25, 2009 | Computers & Internet
BURN FAIL ERROR CODE
I suppose that you have a DVD writer or a HD DVD drive installed by default. I am having the same problems on an Aspire 5920 G with a HDDVD Toshiba and the problem is because of mister Bill Gated and windows vista... the drivers for DVD RW and HD DVDs are all messed up in vista and they enter in conflict with those from the burn program. ERROR 204 corresponds with "POWER CALLIBRATION ERROR" witch means that the beam could not be centered on the row it was writing or that the beam could not write on the disc. You can try a google search for youre dryve type firmware and upgrade it. To find youre drive tipe go to device manager DVD/CDrom drives and copy the name of the device (eg: if it is TOSHIBA DVDW/HD TS-L802A ATA Device search for "TOSHIBA TS-L802A firmware" on the web and upgrade the firmware to the newest on the market). Alternatively you could install windows XP and vurn from XP and you will not experience any problems
Jun 16, 2009 | Acer Aspire 4930-6862 Laptop
Toshiba dvdw/hd ts-l802a double layer dvd burner will not burn dl dvd's, laptop Acer Aspire P920G, win Vista premium
I have the same toshiba burner. You should manually assign a right sector number to a so-called break point between layers of a DVD9, in order to start burning, or to burn successfully with this Toshiba. This requires profound knowledge, and special progs to use. "Imgburn" (freeware) is one of a few.
Jul 12, 2008 | Televison & Video
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
