Question about Car Audio & Video
Kenwood KDC-9011 will not come on.
Face will not turn over, and unit has power. Fuse is not blown, and I have tried the manual open switch. Still nothing. Can some one help
  • 2 more comments
  • archange_dha Nov 28, 2008
    I posted wrong. I mean there is power going to the unit, but nothing comes on. The fuse is not blown.
    I forgot to say Thank You. I really appreciate you help.
    Hey, i checked both ribbons, and they do not have any cracks. however, I did find a resistor or capcitor (slot Q23) that melted the bottom plastic sheet. It is also swollen. Could that be the problem?
  • dennis_bacon Apr 01, 2009
    I bought a kenwood kdc-9011 where is the security code located on the stereo and how do you enter it?
    President:
  • 624 Answers
The problem is most often the ribbon cable that goes from the display to the main board. It must be replaced. There is no other fix for this.
Posted on Nov 28, 2008
  • Dave DeGain
    Dave DeGain Nov 28, 2008
    I understood your problem and I am still convinced that the ribbon cable from the face to the main board is at fault. It is a common problem with this radio.
    It would be appreciated if you would rate this solution.
    Thanks,
    Dave
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
Radio does not turn on, and can not eject cd.
HAVE YOU REPLACED UNIT? IF YOU HAVE THEN IT COULD BE THE SWITCHED / CONSTENT FEED BEING AROUND THE WRONG WAY, YOU CAN TEST TO SEE IF YOU HAVE A CONSTENT FEED WITH IGNITION OFF ON ONE OF THESE, AND A FEED ON THE OTHER YOU TURN IGNITION ON, THE THESE ARE NORMALLY RED AND YELLOW SWAP THEM ROUND, GROUND/EARTH IS BLACK, FUSE N HEAD UNIT NORMALLY BEHIND THE PLUG THAT FITS IN THE HEAD UNIT
Dec 06, 2009 | Kenwood KDC -X815
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Kenwood KDC-MP438U acts as if there is no power to it,dead nothin
The speaker wires are very sensitive. You need to make sure that they are not grounding out. Once the unit senses this it will shut off. Pull the plug out of the back and start over.
Dec 30, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
No power, does not open
the wires from the face to the deck 10.00$ part
May 14, 2007 | Kenwood KDC-X811
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Dec 03, 2006 | Kenwood KDC-715S
Face plate wont move
First check the power fuse as well as the stanby or always on fuse. then if that does not work Try to disconnect the power and standby line and let the unit reset . This should be done for at least an hour or so.. Good Luck
Jul 25, 2006 | Kenwood KDC-7009
Car Audio & Video Logo
400 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
